AC motors and Variable Frequency Drives
skeer
Standish, MI Area
Prolly a dumb question but.. Google returns mixed results on this topic: Can you safely and efficiently control a single phase motor with a VFD? I see things suggesting both yes and no.
As an aside, what about Split-Phase?
MBfreak
MEMBER EMERITUS
Linkoping , Sweden
A single phase asynchronuos motor can of course be rpm controlled by varying the supply frequency ( also the voltage in order to avoid flux saturation at lower frequencies)
The question is if the 3 phase VFD will be happy running just one phase load.
Contact VFD mfr for an answer .
Ola
skeer
Standish, MI Area
So if a VFD whose output it 3 phase isn’t for single phase motors then logically a VFD with single phase out would yes?
I could have worded my original question better but I was not specifying those with only 3 phase out.
N_Jay
The issue with single phase is the starting cap will try to kick in at low speeds, and the run cap (if it has one) will not be the right spec at anything but 60hz.
skeer
Standish, MI Area
I get you, but what about motors without either cap? The motor in question is a Dayton 5K977B.. putting trust in the Googles there are caps 'related' to this motor but I don't have one and she starts beautifully. I just want to safely and reliably control the rotational speed.
I concur with MBfreak, at least in theory ! ;)
What most people don't understand is that a typical 120V/240V single phase motor is "coasting" a large percentage of each revolution. 3 phase motors motors "fill in" that coasting time with more power. This is why 3 phase motors are smaller/more "efficient" compared to a single phase.
If you start driving a single phase motor at less than 60 Hz the amount of coasting time is longer and you will lose power.
skeer
Standish, MI Area
Good information!
Sourcing a 3-phase is on the list.. however I don't use the object this motor is powering on a daily, or every other day basis. So replacing the existing motor is not high on the list unless controlling it's speed is critical to having a 3-phase motor. I'm tryin to keep it cheap but not like Scrooge McDuck cheap.
Sourcing a 3-phase is on the list.. however I don't use the object this motor is powering on a daily, or every other day basis. So replacing the existing motor is not high on the list unless controlling it's speed is critical to having a 3-phase motor. I'm trying to keep it cheap but not like Scrooge McDuck cheap.
Good luck McDuck ! 3 phase motors are expensive because they have 3 sets of windings. Likely more copper. VFDs, even small ones, cost some $.
skeer
Standish, MI Area
Well, I was keeping the tool out of the equation in an effort to be more generic. In this case it's on the new to me drill press. But in general, slowing all AC induction motors.. the info provided in this thread is useful.
American Locomotive
Rhode Island
In general, the only single phase motors that can somewhat reliably be controlled with a VFD are shaded pole motors. These are very basic motors - typically small fan motors. Usually around 1/40th - 1/12th HP.
- Cap Start/Run motors are out because the start switch will re-engage at low speed and cause issues.
- Split-Phase Motors (which your Dayton motor is) will not work because they also have a start switch (just no capacitor)
- PSC motors (permanent split capacitor) will not work well with a VFD because of issues with the capacitor and the secondary winding.
Eh, to be fair, single in/single out, 120v ones can be had for under an Andrew Jackson.
There is no VFD that can be purchased for $20. The "speed controls" you see on ebay and Amazon for those low prices are not VFDs. They're basically just dimmer switches.
skeer
Standish, MI Area
Nope I just had the wrong president.. not Jackson but Grant. And I’m sure ‘VFD’ in those cases is a strong word, but I’m sure as hell hope they aren’t glorified dimmer switches. Lol.
skeer
Standish, MI Area
Definitely solid motor info, thanks for this.
Norcal
Be real careful with cheap VFD's they are junk with no to very limited support, as to a 3Ø motor, industrial surplus or a scrap yard where it can be removed from decommissioned equipment, you do not want the scrap from a motor shop.
skeer
Standish, MI Area
Thanks for all the info guys. Im It sure what the plan is now, but I’ll keep my eyes open for a good deal on 3 phase motor now. I still have the much larger dc motor out there not doing anything..but it’s getting close to firewood time. Might be a later upgrade project this year.
jar944
Northern VA
A quick scan on eBay, used 1/2 HP 3 phase motors run $150-$200 including shipping. 5 HP run $300-$400.
$49
Or
