Acid Etching - Coloubond
AaronJ
Hi Gang.
First post. Love the forum.
My new Ranbuilt 10x8x3/4.5m shed is just up and its time to seal the slab.
... Yes, I wish I'd done the etch and first seal before it was built!
My slab is 32MPA with a hard machine polish (some gloss). I also have 'vermiseal' around the perimeter (steel/colorbond trim seals corrugated wall cladding to slab edge) so not lots of options for washing/flushing.
I will need to acid etch, but:
1. Don't want to loose too much of the smooth finish. I am sealing with a clear semi gloss (Auseal). They been advised to dilute way more than normal (50% rather than 10-20%) to allow better absorption on the 'tight' concrete surface)
2. I am worried about how to protect the colorbond from the acid (re vermiseal will allow liquid under it, but might be hard to really flush well) and
3. how to do a decent coupe of rinse cycles (only 2x roller doors for water to get out.
Any suggestions for a decent method I can use are greatly appreciated?
AJ
bigjon
NSW Australia
I acid etched my floor after shed was completed. No issues. Don't let the solution dry and use heaps of water to clean it out. Don't forget to neutralise as well.
Good luck!
