andyvh1959
I'm close to wiring the detached garage 100 amp sub panel to the 200 amp main panel in my attached garage. I have the ground connected, and soon I'll install the 100 amp duplex breaker (on the open area on the main panel) that will feed the sub panel. My issue is the neutral. See the attached pics for the details in the Cutler Hammer Load Center main panel as it was wired back in 1973. Not impressed with the sloppy wire routing done back in 73 by a supposed "master electrician" as told to me by the original owners. But I've never had an electrical issue since I bought the house in 2002, other than finding live, unterminated Romex wires hanging under each deck, not in a box. This 200 amp main panel also feeds another 100 amp sub panel in the basement.
I just routed the conduit from outside the back wall of the attached garage into the main panel. My issue is I have a #2 AWG copper neutral coming into the main panel from the sub panel. Almost all the lug connections on the neutral bus bar are full, and none of them will fit a #2 copper wire. My question is can I add a separate neutral bus bar to which I can connect the #2 neutral?. From that extra bus bar I can run #10 white wire to a lug hole on the current neutral bus bar. If I can add a neutral bus bar does it have to be isolated in any way to the back of the panel, as in making sure it does not connect at another ground path to the panel and the panel ground bar? Or should I only use a crimp on cable lug which provides a #10 "pin" to go into an open lug hole on the neutral bus bar?
The panel has one ground connection that I can see which is routed out of the panel and down, so I assume it runs to a single ground rod. Again, the house was built in 1973 so there may only be one ground rod. My new detached garage has two ground rods six feet apart. Just want to make sure I am following any codes so when the final electrical inspection is done the end of this month I can pass with no issues. Hopefully the current 200 amp main panel passes inspection based on meeting code from the early 70's.
