Adding pull start to older Onan CCK
Bigblockyeti
Upstate, SC
Ok, this genset is great in that it always starts quickly once primed but requires a ton of amps to get it going, the little mower or motorcycle batteries mounted on many portable generators won't even come close. I'd like add a pull start as I've see on some slightly older Onan RV gensets but I haven't seen anything for my vintage, nor do I have any ideas on the best way to go about this. Anyway, all ideas would be welcome, here's the only picture I have of it:
Bigblockyeti
Upstate, SC
Yes, it is, no dedicated started motor. The RV I pulled it from had 30' of 2 gauge copper wire going from the main battery to the starter solenoid.
Bigblockyeti
Upstate, SC
A rope sheave would be acceptable, just not having anything is the problem. I know it wouldn't be easy but it would be far better than not having a backup.
American Locomotive
Rhode Island
There's a big difference between "motorcycle" batteries and "lawn/garden" batteries. In my experience, the lawn and garden batteries will start these generators (but perhaps not always reliably?) Why not just get a small automotive/car battery and mount it to the cart?
Some CCKs were rope or recoil starts, but those often had magnetos instead. On an electric-start only CCK, you might be able to add some kind of rope start, but you'll also need to
1) Provide power so the gen-head and ignition coils will work.
2) Temporarily bypass the low oil-pressure switch
3) Somehow trick the generator into turning the coil and fuel pump on
Other e-start CCK's had an "emergency" pull/rope start. However they had switches and mechanisms that bypass the oil pressure safeties and applied power to the coil for starting. These units will not start without a battery, or a battery that is completely dead.
Farmall450
Marengo, Illinois
This. I have a Kohler RV genset I've been meaning to sell. You need to power several solenoids to get it going out of a unit. Understandable, since they didn't want a fire when you're sleeping above it.
rlitman
Long Island
I agree with everything except that the fuel pump is vacuum powered. And that's going to make pull starting particularly difficult. Plus how will you get the ignition to work without a battery? You still need a battery for that.
ttpete
Dearborn, MI
Consider going to a Lithium-ion battery or a Braille AGM. Both work very well. The Brailles are small and are used in race cars to crank bigger engines than yours.
Bigblockyeti
Upstate, SC
The fuel delivery on mine is actually gravity fed. I'm considering a lithium-ion battery as their still fairly small and light (anything helps with a generator of this heft) and I have one in my motorcycle that cranks the 2 liter engine no problem, albeit with compression release.
American Locomotive
Rhode Island
I would avoid lithium. Those old Onans have a very crude charging circuit. They tend to slightly overcharge the batteries. Lead acid batteries can take a lot of charging abuse. Lithium? Not so much.
