Air Compressor Tank Explosion Danger
MacMcMacmac
canada
I only ever saw one catastrophic failure of a tank. It was a Van Air deliquescent dryer tank that blew off the bottom head quite neatly all around the bottom weld. It was suspended in mid air from the pipe mains with the valves shut off. That's one tank you NEED to drain. Must have been brown trousers time when it blew.
Hohn
Diesel Central, Indiana
You should drain off the moisture daily (I do it when I remember). With a pressurized tank open the drain valve until the water stops flowing and air spurts out.
I only fully drained (intentionally) my compressor three times in the last 20 years. Once each to replace the drain ****,to replace the pressure switch and to replace the copper inlet line. Completely draining the air out of the tank on a daily basis is a waste of electricity and puts extra wear and tear on the pump.
It’s generally better to drain the tank at something less than full pressure. But it really depends on the valve opening rate. A needle valve or gate valve is much slower acting than a ball valve and is safer at full pressure.
Hohn
Not an engineer, but I'd think a tank would rupture by being over-pressured, more so than developing a leak.
Am an engineer, but not an air tank engineer. So I’ll write in general terms.
The difference between a leak and a catastrophic failure is 1) progression and 2) time. A catastrophic rupture is usually a fatigue failure caused not only by corrosion but by pressure cycles in that corroded and compromised state. A catastrophic failure requires a compromised area that is continuous— or continuous enough to propagate once initiated.
If a tank is leaking due to corrosion, it is scrap. The point of leakage is just the canary in the coal mine— there are certainly main OTHER points of the tank (at a similar water level) that are about ready to fail.
In other words, barring weld defects or bad fittings, a tank is NEVER bad in just one spot, even if its only actually leaking in one location. ASME cert all but guarantees the welds are fine.
In a home garage situation, the risk of tank rupture is extremely low. Not zero, but low enough you shouldn’t worry about it. Most home compressors simply haven’t ingested enough air (and hence water) to sustain the amount of corrosion needed to compromised an ASME-cert tank. In home use, the timeframe is decades in most cases.
Grab a large rubber mallet and whack the tank. It should resonate like a metal drum. If there are any parts that do not, then borescope the tank, easily done through the several ports on most.
Pressure testing is nice to do, but it’s just a moment in time. A tank can test fine on a pressure test and leak the next year if it was used a lot in that year in a super humid area and never drained. This is why ASME actually over-pressures the tanks when it tests them (120% I think).
There’s no replacement for diligent monitoring.
I’ll take a 20 year old USA-made industrial tank (like a champion) over a brand new box store chinese tank every time. The former starts out more likely to have weld quality problems, and will be much more sensitive to the inevitable corrosion that comes because it’s lower gauge material with lower quality fabrication.
My water management plan comes down to two primary countermeasures: a tank drain on a timer that I can turn off and on (briefly burping the drain while in use at regular intervals (say 30 min) and then disabling this when not in use. Secondly, I’m not plumbing my compressor head directly to the tank. I’ll be plumbing it to the shop piping with moisture traps and cooling provisions and then feeding the tank off the shop piping. This provides time for the air to cool (and condense) before it hits the tank.
You can do the aftercooler/transmission cooler thing if you want, or you can do the overkill and overpriced copper pipe water trap things if you want. But just dumping the hot air into a point distant from the tank is often quite sufficient.
HaiKarate
Seattle
My cousin fixed his with JB Weld and has been working for years. I'm not going to swear by it, but I think the tanks exploding are a myth. If you develop a leak or pinhole, it will leak air. Take a tank past it's bursting point and it will explode. It can't explode if it's leaking, unless you pump is building it up at a really tremendous fast amount.
I'm shocked nobody has posted the same picture of the homeowner grade 110v compressor that exploded in a garage 20-25 years ago that has been used to stoke fear in everyone for decades at this point. Can someone dig that one up and post it? These type of threads used to be incomplete until someone posted that example and let the knuckle draggers that comprise the majority of internet know-it-alls to suggest that this will suddenly happen to every compressor tank ever made if you dare look at it.
zendriver
Indiana
That's the exact picture we all have in our heads! :lol:
Being scared is fun and quite popular.
lolaetype
North Western Arkansas
The drain valve was a PITA to turn so I start turning it w/ vice grips... nothing.... so I take it all the way out... bad idea.... boom... hisss....
I replaced the factory drain valve with a brass elbow and ball valve. I permanently attached a piece of clear vinyl hose about a yard long to the valve. My compressor sits next to the garage door. I stick the hose out the door, reach down and turn the valve handle 90 degrees and watch the water and then water vapor shoot out into the yard. Once done I close the valve and coil the hose back under the compressor. I do that about once a month.
johnre
Portland, OR
Either of these?
zendriver
Indiana
This one?
Yep, that's the one - that looks like it had repair welds performed on it, by Bubbles, the chimp.
Who knows what other **** work was done to it, maybe they removed and plugged the pressure relief valve, , because it was leaking? :dunno:
I'm more inclined to believe that a rusted tank will leak, before it bursts, but anything is possible.
john.k
The blasters used to get all the air tanks inspected yearly ........a lot of the air system was really bad with wrong components salvaged from a scrapheap ..........one time the PV inspector was inside a tank ,and the hissing of escaping air was getting louder and louder .......I asked him to get out ,which he did ,next thing was an air blast and a bang ,a rubber plug off a butterfly valve had been driven through the pipe ,exited the manhole ,and smashed a water bubbler 20 feet away .........very lucky escape............The butterfly valves were rated for low pressure dust piping..............Normally not an issue ,until the tank needed to be isolated.
Hohn
Likewise. The instances of an air compressor tank explosively rupturing in a home shop scenario when the tank hasn't been "repaired" or otherwise molested are so rare that I'm not sure I've ever seen an actual verifiable case.
Quality air receivers are not cheap. That's why there are so many junk ones around, flooding the market with sketchy tanks.
When McMaster shows a quality UNLINED 60 gallon tank with pump/motor mount plate is $1500, it makes you wonder about the tank you get when the brand new compressor--pump, motor, and all, is $1500 for a 60 gallon unit.
Yes, that's McMaster pricing and quality, but even a Speedaire tank from Zoro is still $1000 for just a 60 gallon tank with top plate.
Hmm, it does make one wonder.
EDIT: on tank weld quality.... The welds on my Champion tank have the appearance to me of being Sub-arc welded. Imported tanks rarely have high quality welds and often aren't even ASME certified. If you are buying a compressor CHECK THE TANK. I recall seeing the Craftsman compressors at Lowes and seeing rather unimpressive welding.
john.k
another time ,a cheap teflon ball valve exploded right in my face ,and 2,000 cfm exhausted ........how I wasnt injured ,I dont know ,but except for deafness ,I was OK ..........of course everthing came to a halt with no air ,the boss came running out ,not to see if I was OK ,but to yell about lost production.
Skyman
Central Maryland
I've always just left the drain **** cracked ever so slightly open on my tank. When I shut off the compressor, I confirm that I can barely hear it hissing. So it's self-draining.
If it were a huge tank that was in heavy, daily use, I'd try to remember to drain out the water at the end of each working day, which was one of the many daily chores I had when I worked until closing at a gas station as a high-school kid. But, this one has a 22 gallon tank, and it sees only occasional use - even less since I gravitated toward battery tools and away from air tools. It mostly just sees occasional duty inflating tires and blowing stuff out or off with an air nozzle.
bcschief
Crescent City Florida
Had a Craftsman air compressor tank blow out the bottom years ago, it was my grandfathers, and I figure he bought it new about 1963 or 64 when he retired. When it blew, I was sitting next to it airing up a tire or something a couple of my neighbors came out wondering what that boom was.
Hohn
So like 30 years of mostly neglect?
johnre
Portland, OR
Note that my first video in post #47 and @Hohn 's still image in post #49 represent the same incident. And while I also did take note of the hack welding job done to the bung on the bottom or the tank, it doesn't appear that that immediate area was the start of the tank rupture. I'm guessing it started toward the middle of the cylindrical section, where it was about 3/4 torn open around the full circumference of the cylinder - just a guess, mind you.
And it's a hot ********* tank, which can be problematic for drainage if it is slightly sloped down away from the draincock. You can be as diligent as possible about draining the tank regularly, but it doesn't take much movement of the compressor to make it slightly uphill to the draincock on this style of compressor, and if this is the case, there will always be water trapped in the other end.
That's why I'd prefer a vertical tank - the draincock is at bottom dead center, on the axis of the cylinder, so it will drain much more effectively. I'm also thinking that the spherical ends of the tank are stronger than the cylindrical center part, so it's a better area to have water congregate, if it has to be so.
Tynee
In the Heart of the Bluegrass
My 60Gal. mutt of a compressor has a close ****** on the bottom drain, then a 90* elbow to a 6" ****** before the valve. I figure this gives me some water storage at the bottom of the tank that can easily be replaced if I get worried about corrosion, plus it makes the valve easier to reach to drain it. I never get more than a puff out of mine, and I try to drain it at the end of a day of use, plus again the following day after the air sits and cools overnight. I keep my compressor pressurized but turned off.
micromind
Fernley, Nevada, about 30 miles east of Reno.
I will use a street 90 if possible, mainly because if the close ****** gets broken, it'll be a bear to get out of the bottom of the tank. A street 90 is much stronger and usually the pipe going horizontal will break first. Then just unscrew the 90 out of the tank.
Hohn
That's a good idea. I'm going to be revising the drain provision on my Champion 80gal project tank, this seems like the way to go.
GentleManDrinker
I have heard that when a compressor tank fails, it usually just starts leaking though a pinhole that develops. But, although rare, sometimes they will explode and do a tremendous amount of damage.
I have a Sanborn 5HP compressor that I bought new in 1989 or 1990.
So, it's darn near 20 years old. It's an 80 gallon tank and the performance numbers are 18 scfm @ 100 psi and 16 scfm @ 175 psi.
Just last month, I put a new electric motor and belts on it and it is working perfectly. I have drained the water on it fairly often and after hard use.
Should I be thinking about investing in a new compressor?
Should I be concerned enough to warrant having this compressor hydro tested? Doing this sounds like kind of a hassle. I don't know if there would be anyone in San Angelo that does this. If I had to take it to Dallas or Houston, I think I would just rather invest in a new compressor.
Or, should I not worry about it and keep using it until a breakdown and then consider a new one?
I performed a hydro test on a compressor my wife found on the side of the road. Stripped it down to just the tank. On the drain side I installed a PRV for just under double max operating pressure as nd on the other side filled with water in a position with minimal air pockets and connected my pressure washer with a ball valve and gauge in between. Pumped it up and let it sit for about 30 minutes under pressure. I’m confident it will hold air just fine. I’m in the process of reassembling the pump. It should be up and running by the end of this weekend.
R
roger55
Fort Collins, CO
Interesting someone brought my thread back from the grave after so many years!
I no longer have that Sanborn compressor. After replacing the motor, the pump only last 4 more years. It failed in 2012 in the middle of when I was painting my 55 Chevy. I didn't have time to mess with it so I went down to Tractor Supply and bought a 7.5HP 80 gallon Ingersoll Rand. I lucked out that they happened to be running a sale price on it at that time. It's been a good one. Way more capacity than my old Sanborn. I moved from Texas to Colorado earlier this year and I brought it with me. Here it is after getting it hooked hooked up in my new workshop in Colorado:
zendriver
Indiana
Nowadays, it’s fun to have more stuff to worry about.
I find myself looking out the corner of my eye at my 20-year-old Homier Speedway compressor and it’s not even plugged in.
andyvh1959
Green Bay WI
My 60 gallon Sanford (Menards) air compressor leaks from a pinhole in the bottom. But it can still fill the tank enough to generate over 100psi showing on the pressure guage. So if the tank bottom was structurally compromised, and even though it is leaking air, at the moment the compressor kicks out at almost 150 psi, that force of the compressed air is still pushing on that area of the tank, as if the tank had no leak. But the difference is, how much of the tank bottom thickness has been compromised. The tank bottom does not show any deformation as if the air pressure has ballooned it out.
