md21722
I have read a bunch of threads but none seemed to answer my question.
One reason I'm looking for the air dryer is because I have air tools that use a lot of air, like angle grinders. There is usually some condensation coming out the grinder's exhaust. I don't think any amount of air compressor after coolers, or coalescing filters is going to help.
I think I need to lower the dew point of the air to cooler than the tool runs so eliminate the condensate I get at the tool.
Here's why. Say I start the day with filled air tanks. The compressors haven't run at all, so all the stored air is at ambient temperature. I have enough stored air I can run the grinders for about a minute before the compressor kicks on. Even during this minute the tool gets cold enough that I get some condensate. When the compressors run, I get more condensate.
So
1. Am I on the right thinking that the air dryer is the only way to eliminate the issue? Do they make coalescing filters for high volume demands? Something like the Devilbiss DAD-500 says it lowers the dew point to -40F, but also says medium production and is only rated for 25 CFM. Sounds better for something like painting.
2. What happens if the air demand exceeds the rating of the air dryer? Does the air dryer act as a restriction and only flow what its rated? Or does it basically allow undryed air to pass though?
3. I am thinking of getting a 60-85 CFM high temp air dryer and forgoing individual compressor after coolers. The air dryer is rated for up to 200F input air. Anyone see a problem with this? Is there a reason to install compressor after coolers when using the high temp air dryer? So far the highest measured tank temperatures has been about 115 F and I plan on putting the drier after about 25 feet of black pipe. I would think the only reason to use the after coolers is to be able to use a normal temperature air dryer rather than a high temp one.
4. I was looking at the high temp IR models. I know Hankinson is a big name in air drying. Anything wrong with the IR ones? I believe Speedaire's are rebranded Hankinsons.
Thanks!
So
Thanks!
