I'm brand new here- first day, all because of having just purchased a pair of Allen drill presses. i love the old stuff- it was built well and made simple. so i picked up the set and table today from an online seller. this unit is heavy, which i love. We ended up removing the two drill presses from the table to make hauling easier.
So, here's where i need help, and i knew this prior to making the purchase. The motors are 3 phase and my farm shop has single phase. Converting shop to 3 ph would not be cost effective at all. i need help in finding the proper single phase motors for these units. Is Allen still in business? Is it operating under a new name? Or, how do i locate the proper motor configuration? I don't even know the make of the motors. They only have wiring schematic labels on them for wiring in a series or parallel. And the motors don't appear to be the most standard type, as there's no plate with mounting holes, and appear to be simply attached to the drill press via a collar on the shaft. There's an access hole to get at this collar. ( i did not take much time to inspect it closely after unloading.)
There's two Allen-Bradley switch boxes on the unit and the seller told me, on a side note, that these vintage boxes/switches are worth several hundred dollars each?!?! If that's the case, and depending on how my electrician installs new switches, they may be on the market if anyone's interested. Is it possible that there's a connection between the Allen brand displayed on the drill press frame and the Allen-Bradley brand boxes?
if anyone can assist me in locating sources for the single phase motors i'm in search of i will deeply appreciate it!
Steve
Steve
