Another can't decide on coating post. Help
RMatthews7
SC
I'm so confused from reading all of the articles (All Garage Floors seemed great at explaining the basics,) and online stores (Legacy Industrial seemed best until I called, and Garage Flooring LLC until trying to 'chat,') and I'm sure you get these posts from time to time. I need help in deciding what to do.
1st time DIYer that can recruit 2 "helpers."
I have a 1,000 sq ft detached garage located in South Carolina that is finishing up with paint on the walls and I would like to attempt to lay down a ~7-10 year epoxy coating that will have to handle lawn equipment, dropped tools, rolling workbenches and metal-wheeled engine lifts, hot tires, metal grinding sparks, saw dust, gym equipment (thinking a rubber mat placed on top is the best solution here,) beer brewing, and ping pong. I bought the home with the garage framed, and am not sure if the concrete is sealed, but it does seem suspiciously smooth compared to the driveway. I did the water drip test today and it definitely isn't like the driveway which soaks in, but it also doesn't really bead. The water semi-soaks, then can move around on top and seems like it has to evaporate. Picture attached. Looks like I'm grinding the floor...
I have blue/gray satin walls, white flat ceiling, and 6 VERY bright High Bay lights. I'm leaning towards a medium gray flooring and am not sure about the gloss/satin finish for the floor (due to the lights.) I really hate the look of flakes, but definitely don't want a slippery floor.
It's 40-50F right now where I'll be applying it and I can roll up two 15' doors on each end of the garage for ventilation and to either slow or speed up the curing process. I'm most concerned with my ability as a new DIYer to be able to have the right timing for mixing, pouring, rolling, curing. I can dedicate days to building up coats as we've had it cleaned out for 5 months already...
There are also settling cracks from the few years the building has been in place. They don't seem too bad, but I'm curious about the cracks on the concrete on the side of the slab. Picture attached.
With all of that said, I'm sure there's something I should have included and didn't think about, but I'm mostly looking for the right product and floor prep for the size and use of the garage space.
Nohr-S Epoxy/Polyurea, TLHS vs. 100%, HD/SD Kit, Hellfire, Xtreme Set 100... About the only thing I know I'm doing is grinding the floor (dry/wet?) LOL
Thanks in advance for anything you can do to recommend or warn against!
FJ4FUN
NorCal
Feel free to contact us directly and I'll get you pointed in the right direction...;) Wolverine Coatings ships out of S. Carolina so you'll save a few pennies on shipping anyway.
Bert
Andy Smith Jr.
Houston, TX
I think a traditional epoxy & urethane system or Hellfire system would be the way to go. I'm not a floor coating guru like others on this board but i've been following for a long time and it seems like with all the abuse this floors gets, those are the best 2 options judging by others post. Urethanes comes in a variety of colors and Hellfire has a really cool industrial floor look.
clydesdale
Brewster, NY
What makes someone a hellfire candidate? I have not decided on a coating yet either and am leaning to polyurea, but have not fully decided. I looked at the pics in post #4 and as long as it is not super slippery, that is kind of what I am looking for. But, not crazy about having to do 3-4 coats. So, what makes someone a Hellfire candidate? Thanks.
R
RMatthews7
SC
Thanks for all of the follow up! It's been too cold to do anything, work got busy, and I'm just getting back to the garage floor planning.
Anyway, just an update and question... You get a lot of private messages from dealers on here, so that's been good to look into. I tracked through the Wolverine coatings, realized the pot life makes it impossible for me to think I can handle a system like that in my newbie-ness.
However, in that discussion with a local distributor though, I came across Rust Oleum's 9100 Epoxy Mastic that is used in industrial situations. Definitely not the big box stuff, but I've come across no examples of someone using it on their garage floor. It's in manufacturing floors, tanks, and even traffic lines. Any thoughts?
FJ4FUN
NorCal
Don't let pot life concerns dissuade you! The vast majority of our customers are "newbies" and they all get through it just fine. Our LiquaTile 1143 CFLC system has an added benefit of not needing the urethane clear coat which cuts your coating effort by a third. About the only time you start to run into pot life issues is when mixing/applying the larger 5+ gal kits (which is why we do not sell these kit sizes to the general public). A 3 gal kit can easily be mixed and applied by a single person if you can follow basic instructions, it's a breeze with two people.
The "hard" part is prepping properly. If you're going to take the time and effort to properly prepare the floor then you might as well apply the best material available.... :thumbup:
rebelranger
RMathews- just a suggestion all the epoxy companies are going be generous and say their product is great/the best without down talking others, but none tell you why. They all tell you what the product does but not why YOU need it. Just think about what you use your shop 99% of the time and use the cheapest product that gets you the look you want. Like concrete look and clean up your mess quickly get Eagle or AR500 coating/sealers. Once you start spending over a $1 a sqft you are looking for a look not value or usability. I've been in your shoes and still am until weather warms up but I've made my decision.
LegacyIndustrial
deerfield, IL
Low cost, one color, function over form.
