ddawg16
This question has been asked and answered 'many' times.....and being the type that does not accept the first answer I see...I did research....
This has to be the best reason why most cities don't allow it...(source - All Experts)
To summerize - Yes, the NEC code does not prevent it....
BUT...many municipalities have taken the above position....
Or, in other words....it's up to your local inspector.....which means, "That's not the hill you want to die on."
So...do it his way and move on....
In most garages....attached or detached...conduit is not necessary unless the environment will require it...or if local Codes require it. If this garage is going to remain in the open stud mode...with no drywall or wall covering...conduit may be become a consideration...simply to add extra protection to the wiring. However....if you use conduit - either PVC or EMT....most juristictions will not allow sheathed or jacketed romex to be run in long lengths of conduit...only short *******...this is becuase the individual wires will now technically have 3 layers of insulation...the original black or white covering immediately over the conductor, the outer jacket of the romex...and then the conduit...and in long runs, overheating can occur due to lack of heat dissaption. In most areas..(check with your local authority)...long runs of romex in conduit must have the outer jacket removed before it is pulled into the conduit...and if you are going to do that - you are just as well off pulling individual colored runs of THHN wire....which doesn't have the outer jacket covering that romex does. Again, your local inspector will know if the outer romex jacket removal is required in conduit in your area (it is here...other then short ******* of conduit or sleeves thru wall) .
