Anti-Skid Size Selection
fredvm
I recently applied EpoxyMaster (10mils DFT) in my garage. Having used their product before in my basement utility room, I didn't care for their aggressive aluminum oxide. For my garage, I used Legacy's soft-skid media (fine size-40 mesh) and mixed it in with the EpoxyMaster product. We liked the feel of that much better and it seemed to do the trick until we realized that it wasn't anti-skid enough for flip flops and bare feet, of which little girls have lots of in the summer :) .
I was considering whether or not to put a top coat on, so I guess this makes that decision. The question is now what size to use for anti-skid. The top coat is 5-7mils DFT. I wonder if using the same Fine size on a top coat 2/3rds the thickness be enough to make the difference or if I ought to bump up to the Coarse size at 16 mesh.
Thanks for any and all feedback!
Armorpoxy
We have a really nice small particle size non skid called Armorgrip you can add to any topcoat. It's not gritty, disappears in cleats and gives excellent nonskid properties.
F
fredvm
The product will be much more effective in a thin clear sealer.
Thanks for the reply Scotty. I'm considering bumping up to the coarse grit just to be safe. Is that advisable or do I run the risk of having a floor that is way to bumpy?
Also a question on the application rate. The epoxy was 7.5 gallons for the area I applied and accordingly used 3 oz per gallon. The sealer I am using is about half that, at 3 gallons. Do I keep the same 3oz per gallon and use less in the same space or bump up the rate to use the same ~20oz in the entire space?
Thanks again!
LegacyIndustrial
deerfield, IL
Use the same ratio. You can see the grain size pretty good in these pics.
1st Pic: Ultra-Fine
2nd Pic: Coarse
3rd Pic: Fine
