Anybody know about air compressor filters?
RonRock
Iowa, USA
So I'm looking to add to my airline drops. I have piped my shop with a loop of 3/4" copper with several 1/2" drops. I have already finished a couple of the drops with a water trap and regulator that I had on hand.
So now I want to finish a few more of the drops, and have to search the bay for more water traps.
The ones I've found that would work for me have a spec that I don't know.
Filter element: 5.00 µm
Filter element: 40.00 µm
So what is a better filter? And what does the µm stand for? I'd guess parts per million, but I'd also show that as ppm.
More importantly than what is better, what do I need for my backyard shop. Defiantly not a production shop, just my shop looking for a decent air supply.
md21722
Mt Juliet, TN
5 and 40 micron
I prefer the ones with an auto float drain
I recently switched from a 40 to a 5 micron filter and regulator because adding a float to my 40 micron was something like $40 and I wanted to see how the 5 micron filter compared anyway.
I am using a Parker 7F series with a metal bowl and 1/2" NPT fittings. So far so good.
R
RonRock
Iowa, USA
Good idea! I was just about to post this,
"micron is an unofficial name for micrometer (μm). Micrometer (μm) is a metric measurement unit of length"
So I was able to find out what "μm" means by copying and doing a Google search. No keys on my keyboard for μ.
Thanks for the pointer.
R
RonRock
Iowa, USA
Thanks md21722. So does the auto float drain actually blow off the water in the trap when it reaches a certain level?
R
RonRock
Iowa, USA
The ones I already have installed are Norgren F73G-3AN. I like the size and they seem to work fine for my needs. They have 3/8" in/out and a manual valve discharge.
md21722
Mt Juliet, TN
In theory it will. I don't get as much water as I used to since I redid my system and every few days I blow off the line to see how much water I really got in there. The auto float will also drain when the pressure reaches 0 like the other style.
RayBob58
St. Louis, MO
We've got thousands of traps in my workplace, and all were originally auto-drains. We started removing the floats and replacing them with manual drains years ago. The auto's leaked air so badly it was costing big money.
stonesfan68
Houston, TX
hnsy
Good question / post
Sent from my Nexus 5 using Tapatalk
