Anyone ever scrap out a camper?
Ultradog MN
Twin Cities
I see a lot of old campers that are shot and can be bought for $500.
Am wondering how big of a PIA it would be to tear one apart for the trailer frame. The wood I could burn and scrap the aluminum.
Anyone done that?
I'd like to build a bunk house to replace our old Airstream trailer up at our hunting property. Make it kinda cute like my deer blind.
Anybody scrap out a 20' camper. How bad was it to do?
Thanks
racecougar
Missouri
It's a PITA if you're doing it by hand. Not so much if you have a grapple bucket. Note that depending on the camper, the frame might not be worth the effort. Plenty were built with awfully underwhelming underpinnings.
niget2002
Josephine, TX
My grandparents sold their last fifth wheel trailer to someone looking to do something similar. They pulled that thing all over the US and by the time they were done with it, it wasn't really road worthy and barely had one or two more tows in it. I think the guy ended up just using it 'as is' and building a carport/cover over the top of it.
It might be easier and cheaper to just find a used camper that's still half-way decent vs rebuilding something yourself.
As others asked, do you really need the mobility?
driftpin
I was in the fire-rescue ambulance returning from a call, where we transported a patient to the E.R. of the local public health trust hospital. Just as we turned off the boulevard, 2 blocks from the fire station, I saw something unusual. It was the entire side of a slide-in camper, lying mostly in the sidewalk, and extending into the street gutter.
There was a concrete utility pole in the R.O.W. and apparently, from the white paint on the street-side of the pole, someone had cut the corner a bit too-close, and they neatly peeled-off the aluminum panels comprising the entire right-side of the camper. It fell to the ground, and interestingly, the large awning window in the panel wasn't even sporting any shattered glass.
After shift exchange, one of my now off-duty co-workers and I returned to the intersection, and he helped me load the side of the slide-in camper into my truck. I took it home, disassembled it for aluminum scrap and got some pocket-money. The 'disassembly' was already done, so it was easy to scrap.
carlaisle
I've seen it done and that third party observation was enough to convince me I would never want any part of it. It will be less work to stick build a 20' bunkhouse, even if you have to carry all the materials to the building site by hand.
U
Ultradog MN
Twin Cities
Good replies. Thank you all.
A bunch of additional thoughts here
I have a loader with forks. I could pierce through the walls and pull it apart in big chunks and drop them on the burn pile up there. Rake up the remains.
I'm thinking I could still get a few $ for it when the day comes we quit hunting/fishing if it was easily transportable.
I computed an approximate weight and it would be in the 5K lb range.
No bathroom or plumbing. We have an out house there. Haul water from home like we do now.
Yes, stick built, well insulated -all 4 sides + top and bottom. Decent residential vinyl windows. Frame a hole for windoW AC. Use electric heat.
Build it at home where all my tools are - on the apron In front of the garage. Lift the floor, walls, roof in place with the loader. Maybe do 9 or 10' wide. (I can do over dimension loads.)
Sell the Airstream To buy materials.
No more bugs, spiders or mice.
JeepYJ
Why not just start with a utility or equipment trailer and build a tiny house on it?
Quite a bit of a camper won’t burn or will be stuff you’d probably not want to be burning.
