Anyone here ever carve granite
elmer
Detroit
Scored these 3 surface plates at an online auction.
24"x36"x4 1/2" - $25 , 18"x24"x4" - $35 and 18"x24"x6" - $30 .
All grade A and just a month out of date. I am gonna keep one for a surface plate and thinking of trying my hand at stone carving with the other two.
Maybe my house address and maybe my own grave stone.
PCustoms
VT
Keep/sell the plates and go get a chunk of material at the landscape yard.
Funny, odds are those came from VT but they never show up cheap around here.
Beerhippie
Far NE Oregon
Let's not get ahead of ourselves here....
I'll second the vote for resell and buy a less valuable slab for practice carving. Pretty sure you can easily double your money on those.
Get a good respirator before dry-carving stone. Silicosis isn't a city in Italy (but it is common among stone carvers in Italy).
gte718p
That is a crime for them to go that cheap.
Obviously, no one wants them or they would have gone higher and Shipping is a killer on anything that heavy. However, I'm in the crowd that says it is a shame to ruin a perfectly good surface plate. The counter top or tombstone manufacture generally have drops that they give away or sell cheap. There is probably a GJ member or a PM who would double your money .
E
elmer
Detroit
OK maybe I'll make a couple funky little end tables for the patio or basement . Not really into selling small items.
motorcitykid
Detroit River
Maybe trade them for tools or something you could use if you didn't want to sell them. They're yours to do as you wish, but the utility value may be better traded. If you change your mind let me know, either way bests of luck.
E
elmer
Detroit
As an address block, glue raised numbers on the smaller plate. Raised numbers are much easier to read and they will not harm the plate or you!
Thanks for the good advice but if I were to put the granite in front of the house I would want the numbers chiseled in stone
gahrajmahal
Cincinnati, Ohio
I thought of doing this (the stone carving part) myself. I was going to get sink cut outs from a granite countertop company. I’d suggest you do the same before you go carving up those nice slabs. Just because, I will probably **** at it the first time or two. I have carved a bit of stone, nothing fancy, I built stone steps, then a stone patio at our house. Here in Ohio the field stones have the most awesome fossils so where I was matching the stone to pavers I carved them free hand with my Diamond disc.
Milton Shaw
A lot of stone work is done with a rubber membrane stencil that is attached and then sandblasted to form the pattern. Most monuments in cemeteries are done this way from what I have seen.
jblnut
In the Middle of MN
If you were closer I’d get you some far less expensive granite to practice carving with. This site is about 40 acres with stuff like this all over it. If you can picture a size of material from 6’x6’x10’ down to 4”x4”x2” material it’s all here. Mama Bear was eyeing treasures I had to later retrieve lol
As far as carving granite goes invest in a set of diamond bits for a dremel for fine work and other diamond encrusted grinding things for other sized grinders you may have. Chiseling takes an enormous amount of skill to get right.
