Apoxy Flooring
gmhill33
Greetings All,
I want to use some kind of cheap epoxy on my garage floor (maybe like the kind at Home Depot). Do you all have a particular kind that you would recommend? I want to be able to roll a floor jack around on it though. I have a motorcycle and I have it on the jack whenever I get done riding and usually move it to the side with it on the jack. Can the epoxy flooring material take that?
Thanks,
Gary
aandpdan
In between MA and PA
A lot depends upon your preparation of the surface.
I've seen the Rustoleum system used in a fire station. It's holding up pretty well considering the abuse it gets (big hot tires).
If you just want to change the color, maybe concrete stain?
G
gmhill33
Thanks for the reply. I don't only want to change the color, I like the look and the durability also.
Gary
