Are Rolling Bridge Jacks for 4 Post Lifts interchangeable?
SnowCub
Bedford, MA
I have 2 Quality (Challenger) 4 post jacks at my home and each one has a Challenger RJ3.5 Rolling jack. Last Spring they both started leaking oil. My vendor promptly fixed one but took their time with the 2nd one and now it seems to be leaking oil again. I'm thinking it's time to buy a new bridge jack. Do I have to get another Challenger Bridge Jack or are they interchangeable at all? Could a BendPak, Danmar, etc fit? Would they be any better quality?
mikegt4
sw ohio
Learn how to replace the seals your self. It’s not difficult.
I agree, hydraulic cylinder seals are not difficult to replace, they are nothing more than a large syringe like your doctor uses to give you a shot. Buying a $1500 rolling jack instead of $50 worth of seals doesn't make sense. If nothing else just removing the hydraulic cylinder and taking it to a "real" hydraulic repair shop. Look for places that specialize in farm or heavy equipment hydraulic services.
no704
I’d be surprised if a seal kit is $30. Probably take 2hours the first time. Likely more $ for new fluid.
SnowCub
Bedford, MA
The guys I bought the lift from charge me $295 each time they come out to my place. So I figured this would be the 4th visit within a year, 4 * $295 is $1,180. So from that price it made sense to me to just get a new one. They reinstalled the "fixed" pump on November 22 and its leaking again. How would I look up how to fix the seals? YouTube?
finn
The UP, God's country
It’s largely intuitive.
pbon
Hydraulic bridge jacks are not all interchangeable. There are sliding versions, rolling versions, adjustable width versions, some sit higher or lower than others, etc. With research, you might find someone who has figured out what alternatives fit your lift. I followed only the alternatives to the Bendpak jacks, which are expensive.
finn
This. Plus, the wheels generally ride on a flange formed when the ramps are stamped out ( or fabricated). That flange (or call it a rail) may be of an incorrect height to be compatible with the bridge jack wheels from some other manufacturer.
05snopro440
Sherwood Park, Alberta
It's a porta-power pump going to a hydraulic cylinder. It's certainly not a complex hydraulic system that would be hard to fix. Mechanically the bridge jack is very simple (I have one). Replacing the entire unit because of a leak is akin to cutting off your leg because you skinned your knee.
