ImprovementX
Hi,
I tried to email AromorGarage, but haven't heard from them yet. I wonder if anyone here has experience with their products to help me out.
I ordered the military coat kit.
Unfortunately the top coat canister arrived damaged and leaked a little, is it still safe to use or should I request a new one?
I can't understand if I got all the topcoat cans or is there still a pending shipment.
I have two gray 2:1, cans which is the epoxy coat.
I have two orange cans 1:1, which is the primer.
Then I have quart can of aluminum oxide (46 grit) and one gallon can that says topcoat. Do I mix aluminum oxide with the topcoat? Is that what is referred to in the instructions as 2:1 mix for topcoat?
attaching some images for reference.
Last question is about acid etching. I have the can of muriatic acid, but no "Acid Safe solution" which is mentioned in the instructions. Also no TSP powder. I don't mind getting these at the store if I can, because I've been waiting for a while to get everything. But I am really not sure what am I missing if anything.
thank you
thank you
