Assorted New Small Engine Tools
Skin
Boston
Boston
Price
Varies
Clearing out a bit and found a bunch of spare small engine tools. All are new and all are made in the USA unless told otherwise. Shipping included within the US. Any questions shoot me a PM.
8x Tecumseh Carburetor Needle/Seat Tool 670377. This is used on the vast majority of their small engine carbs to remove and install the seats and the plastic emulsion tubes out of the fixed jet carbs. The hook will also work for removing Briggs seats.
$13.00 ea. Shipped.
2x Tecumseh Fuel Line Removal Tool. Used to pry fuel line off inlet barbs without ripping the line up. Also works well for prying on electrical connectors and spark plug boots. Kind of the pocket screwdriver of the small engine world.
$15.00 ea. Shipped
2x Tecumseh 6" T30 Torx Drivers. Used to remove Carburetors on many Tecumseh engines made from ~2000 on. Will give you enough deflection to remove carbs off the OHV engines as well.
$9.00 ea. Shipped
1x Tecumseh Starter/Bendix remove & install tool. Used to remove and install hog rings on many small engine electric starter motors.
$55.00 ea. Shipped
1x Briggs & Stratton 19495/DTI-33 Digital Crankcase Vacuum Gage. Adapt an oil fill cap to a barb, connect a hose, and it will read vacuum from 0-60 in./water lift. (Universal use)
$70.00 Shipped
1x Briggs & Stratton 19480 Tang Bender. Used to set governor speeds on fixed speed engines (not just Briggs) by bending the throttle tang.
$10.00 Shipped
