audio ground loop
PoorOwner
CA
Audio issue here, 2 circuits in the room.
When I plug one audio device 1 in circuit 1, and plug device 2 to circuit 2.
both devices are connected via an interconnect cable (RCA / HDMI etc)
There is a big ground loop hum. Text book example, right?
Can I custom wire device 2 so it is using neutral and hot from circuit 2, and ground from circuit 1?
In theory, the ground loop should be gone? While maintaining ground fault safety?
The two circuits are adjacent breakers in the same panel. The ground wires go to the same panel same ground bar.
I kept searching this issue and those crazy audio "file" people say they just don't use the ground wire. No way I am doing that.
P
PoorOwner
CA
receiver and projector connected via HDMI.
I also want to plug in a subwoofer later on, same challenge.
P
PoorOwner
CA
The HDMI cable does carrying a signal ground.
My solution right now is a long extension cord and plugging everything into the same circuit.
SGKent
Citrus Heights CA
PoorOwner - your explanation is hard to understand. It almost sounds like you have central Device A connected to Device 1 via HDMI, central Device A connected to Device 2 via HDMI, and Devices 1 & 2 connected to each other via RCA. Is this correct?
Please list the devices you are trying to interconnect, and which one(s) is/are creating the hum.
P
PoorOwner
CA
I have an amplifier on circuit 1 and a projector on circuit 2.
When I plug in the projector (into the wall) makes a loud hum in the speakers connected to the amplifier.
In terms of LOW voltage connections it goes
projector <-hdmi-> receiver <-rca-> amplifier.
receiver and amp plugged into circuit 1.
when I unplug the HDMI cable from the receiver or unplug the projector, the hum goes away. No TV cable is connected to the system.
country83
Some audio schematics I've seen for buildings specify "same phase same leg" for connected equipment. If you have them on adjacent breakers they would be on opposite legs. Try changing to the same leg and see if the issue goes away.
Sent from my XT1635-01 using Tapatalk
P
PoorOwner
CA
I didn't want to lift the ground on the projector, but I am pretty sure the noise will go away.
So my original question is can I ground the projector using the same ground as the amp.
It's a bit of a hack, but it is safer than no ground.
If I swap the ground wire over, is there any scenario you can think of a ground fault would not trip a breaker ?
If youre asking if its NEC compliant then the answer is no.
ASHMAN_AZ
Vail, AZ
This is good advice.
I am having a similar issue with my outside cheap TCL porch TV connected to the inside main stereo. The RCA ground loop isolators helped remove most of the hum, a power conditioner at the AMP rack did not help. I have three different breakers between my main TV, AMPs and out side TV all ground looped by RCA cables.
different breakers are not the issue. Just make sure theyre on the same hot leg in the panel.
P
PoorOwner
CA
Were you the one who rewired the two prong to 3 prong?
No.. I changed the amplifier to a different brand and it is a bit different. lesson learned. keep everything either 2 or 3 prong and don't mix them.
