Auger bit for wiring
nate379
Palmer, AK
I know this is a dumb question, but is there a standard size bit to use for when running wiring through studs?
I have drill bits up to 2" in 16th increments.
MrMark
Southern Cal.
Yes, 7/8
I use 3/4 for one romex and 7/8 for two romex. 7/8 will handle up to three romex w/o crowding. Most electricians just drill 7/8 holes everywhere.
ishiboo
Oshkosh, WI
Yes, 7/8
If you only buy one bit, get a 7/8 or 1" stubby auger with the self-feeding screw on the tip.
Teken
The Bad Lands
+1 :thumbup: Also make sure you're drilling the holes dead center, otherwise you will need to install some metal stud plates.
I installed the metal stud plates anyways, just for added protection to guard against future brain farts, or when others besides me may be doing some work on the home.
Busted_Knuckles
Northwest Illinois
Keep an eye out for nails that might be holding the sheating on your house, coming partially through the studs, it takes little to nothing to wipe out the auger bits when you hit nails or screws (been there...).
dipper
Rochester, NY
i highly recommend the Irwin speed bore bits. They do a good job, takes literally 4 or 5 seconds to bore thru a stud.
Teken
The Bad Lands
Any reason that I couldn't use a reg twist drill bit instead of buying something?
One will take longer to bore the hole . . . The spacing between the auger as you can clearly see is much wider . . .
Time isn't a problem for you, so use what you have on hand . . . Now, if you plan on drilling 99999999999999 holes, that dog won't hunt for long I can assure you of that! :lol_hitti
ishiboo
Oshkosh, WI
A twist drill bit has to be pressed against the stud, do a handful of holes or any holes standing on a ladder, reaching, etc. and you will be very happy you got the self-feeder. :)
Spade bits just kinda ****, I'd use a twist bit before a spade. Foresner is the most $$ but leaves the best hole of the hole bits.
Aceman
Eastern Oregon
Everyone uses 7/8's for the most part. If you use 1" you have to be EXACTLY dead center or you'll end up using nail plates on every stud. 7/8's is hard enough as is.
You need a minimum of 1.25" between your hole edge and the edge of the stud or you'll need nail plates.
Busted_Knuckles
Northwest Illinois
Ive been using these Bosch Daredevil hybrids, and for the $ (2.26 from Amazon), they are hard to beat. and they really do work as shown, the threaded tip pulls them through in a hurry. You can hit a screw or nail with one of these and it doesn't ruin your day (Ive been doing allot of remodel work, with hidden fasteners in the studs)
Stuart in MN
Minneapolis
For a homeowner, and the limited number of times you're going to drill holes for wiring, I'd say use what you have on hand.
ishiboo
Oshkosh, WI
I want to try one of those Bosch bits.
Me too, they look interesting. The problem with the normal spades is a) they don't have self-feeders, and b) whenever I drill an old stud or harder wood, they either get stuck halfway through or end up exiting the stud without drilling the hole, making a big splintering mess.
I have mostly Bosch power tools which I mostly love; should give those bits a shot.
Busted_Knuckles
Northwest Illinois
This last week Ive been wiring a 1904 Farm House, built out of local hardwoods (so Im told by the old timer Ive got working for me, its so rough sawn, I cant really tell what it is, but I think it is Fir)....the bits tear through it. The studs are sooo hard, Ive been shooting 3" x.120 Paslode nails at 150 psi, to attach a new pine 2x to existing framing, and still wind up with proud nails. Never worked with such "hard" wood before. Great bits. The only thing that doesn't work great with them, is they stop pulling as the threaded tip makes it through the other side. You have to give it a little wiggle/push to break through the other side. Its allot of bang for the buck.
