Floor prepped with Kilz Concrete and Masonry Etcher in basement. I purchased a three gallon kit from Epoxy Plus (metallic). As many have, I've done hours of research. The Kilz did not give the recommended "grit" appearance (60-120), but absorbs water very quickly. Some areas seem rougher, but a majority is more smooth than I feel comfortable. I filled the only cut seam in the room also. I am on the fence about acid etching but feel it will be necessary due to the smoother than preferred surface.
The room size is approx 280 sp ft. I have a roller and squeegee because I have not decided on application yet. Not a notched squeegee because I hadn't planned to make it that thick.
I have some time to acid etch, as the humidity is >85% and temp is a little cooler this week.
Any advice would be helpful!
