Thanks guys
Can I save a reasonable amount of gas by setting the pilot flame as low as possible?
what gas valve do you have on your furnace?It should be as low as needed to accomplish its purpose. There is usually an adjustment and a spec on pilot flame width/length. You will save a little gas by having it correct.
Mine is presently messed up because it is way too big a flame and I can't turn it down for some reason. The pilot adjustment screw doesn't do anything.
My pilot adjust screw was actually a screw within a screw. One screw came all the way out, then inside was the actual adjustment screw, with a slot for the a flat head.
Typically you are looking for the smallest possible pilot to prove your flame and light your main burner. If the thermocouple proves the flame your burner should light within a few seconds of activating the main valve.
If the main burner fails to light within 1-3 seconds you should adjust pressure or thermocouple height.
The fail proof way is to set the pilot pressure to manufacturer spec. and adjust the thermocouple just high enough to prove the flame.
The only real danger is if the pilot proves and the flame is too low to light the main burner you can have gas spilling out for a while before it ignites and it can cause a small explosion. How bad do you like having eyebrows?![]()
I can't see your picture? It has a cap (Phillips screw) that removes to allow access to a small slotted screw in a bore. It is right next to the fitting for the aluminum pilot tube.
There is a larger, easier access, plastic slotted screw on the regulator. I wonder if that is the main regulator adjustment?
You are correct..I wouldnt paly with regulator adjustment unless you have a manometer on your burner manifold
