blazemaster83
I have an old solar 550 high amp charger that my employer was throwing out because it has no output. I took it home, got it on my bench and did a little testing. It does put out dc voltage, and the switches/gauges all seem to work. The problem is it doesn't put out any amperage. With a low battery connected, i get 1 amp of draw through an amp clamp on the dc cables. I took the rectifier plate out and all the diodes did not look burnt out, they looked just fine.
Electrical stuff is not my forte, im more of a machinist/mechanic. Am I testing correctly? Do I need a new rectifier plate? This thing is pretty simple so i cant imagine theres much to go wrong.
I did some searching and cant find much on low amp output
