Bench grinder Wheel Flange
lodestar
Montana
Just curious if there should be a washer on the spindle b4 the flange and one on the outside. This is how it was when i bought it. Is this how it normally is? I bought this and it has 3/4" wide wheels. If I didnt use the washers a 1" wheel looks like it would work. ?? Thanks for any advice.
lafester
Northern CO
Well you certainly don't have to use a washer if you don't want to.
Not sure if they came on new ones or not... maybe check the manual?
I have found the right side sometimes rubs without a washer so you might check that first.
torqueman2002
Nice looking round top.
Here's an expanded parts view from the user manual. No washers.
IIRC - I downloaded the complete owners manual from Vintage Machinery website.
These publications include old catalogs, manuals, parts list and historical documents for many manufacturers.
Filter results by Publication Type: "Grinder"
http://vintagemachinery.org/mfgindex/detail.aspx?id=222&tab=3
1" may fit, but a 1/3-HP might struggle.
exmaxima1
Midwest
I certainly can't see the point in adding a washer with such a sloppy ID against the shoulder on the shaft. The standard flanges are already a much better fit.
