Bend Pak HD9 Casters
Stucazz63
Coquitlam, BC Canada
Hi all, I'm starting to drywall my garage and need to move my hoist out of the way. I have 4 Casters laying around that are rated at 1000 pounds each that I would like to use to move the hoist. If someone that purchased the caster kit with their hoist could send me some dimensions of the caster frame it would be greatly appreciated. Here is a picture of what I would like to weld together.
Thanks, Mariano
Junkman
Northeastern CT
If you are close, I will loan you mine. I am 45 minutes from Hartford CT, Providence RI, Worcester MA, on the MA/CT border near Southbridge MA. You will also need the pins.
Junkman
Northeastern CT
What a co-incidence. I am right next door to you......... but the doors are about 3000 miles apart. My camera is broken, so it will be hard for me to get you pictures. It is basically a squared off "U" with a flat welded to one side and the wheel bolted to that flat. Hole drilled to accept a long pin. Check the lift post for the hole diameter. Not much too it.
