BIG light switch
motorbreath53
SoCal
(tried to post this once... and appartently my laptop didn't approve..)
Yea, i'm a big nerd...
but can a switch like this be used as a light switch without any saftey concern?
thanks for your time.
Danny
malibu101
Walnutport PA
Yes.
The only potential problem is- Are the lugs inside rated to handle "small" 12 or 14 AWG wire?
If the lugs can handle the wire, you could use a 100A disconnect for a 20A load.
Mattlt
MN
Since this looks like a 240V switch, you'd only be using one side or leg of the disconnect. The other side would be left empty.
You probably already knew that...
GarageEnvy
Fresno
Why am I somehow picturing this? It's alive!
bradleykd
Georgetown, KY
i think that's a novelty that would wear off quick... those things have a pretty loud pop whenever you flip it. you'd never be able to sneak out to the garage... lol
Aceman
Eastern Oregon
I wouldn't use that personally, a snap switch is more convenient.
It looks exactly like a Siemens disconnect, so the lugs should be rated to handle #2-#14 wire. The one in the picture is Nema 3R(rainproof), if you plan on using it indoor you'll want Nema 1 instead.
motorbreath53
SoCal
I knew about the noise that these produce... small price to pay if you ask me:thumbup: I found a slightly smaller one than the one in the pic that will get a more appropriate handle...
I'll post pics of what I end up with, but it might be a week er' two... If I don't finish putting the kitchen back together, my wife is going to leave me for the UPS guy...
thanks for the help.
motorbreath53
SoCal
aww hell... I was sure that I needed the BIG switch... till I found this...
This might be the most bitchin switch i've ever seen for a garage...
specially' with a cool keychain hangin from it...
mrb
how about finding an old allen bradley control station with red on and black off buttons and wire it up to a contactor? that would be pretty cool.
tdkkart
Eastern Iowa
Yep, works great, until they fill with spider webs and/or grain dust and blow the cover off when you switch them on.
Seen the film, can't find an example right now.
In an industrial enviroment you never stand directly in front of the switch box when you turn it on, always stand to one side.
Years ago I moved into a rental house that had been lived in by an old lady for years. First time I turned on the microwave I got a **** and smoke from the outlet. All the outlet boxes in the kitchen were filled with dirt,grease and cobwebs, combined with loose screws on the outlets and high loads made for a couple neat smoke shows.:shocking:
