Block Heater working?
Ramper
Southern MN
I had a Kat's 11419 block heater installed in my daughter's 2009 Honda Fit by the auto shop at the school I teach before winter break. Over break it did not seem to work. I plugged it in to a Kill-a-watt tester and it read 0 watts. Then I tested the continuity between the two prongs on the three prong plug, no continuity. I brought the car back in and they "checked" it.
I tried the same two tests today and no watts on the meter, no ohms on a multimeter and no continuity.
Am I testing wrong? The car is in the garage (does the heater have a sensor to only work when cold?)
The shop teacher is leaving in a few weeks and I don't want to stress him if the heater works. The car is LOW and tough to get under, so I want to be sure it is not working
65ranchero
Danville, VT left NJ forever
After doing cursory search , several things show up.
!) possible burn out if it was checked for operation out of liquid
2) a air pocket in the cooling system ( if the system was not purged see item 1
3) possible it was started with it plugged in causing the water pump to cavitate creating many bubbles in the coolant see item 1 ( though I doubt it)
4) there seems to be complaints that the unit failed
That unit does not have a thermostat ( ambient temp sensor)as far as I can see.
kbeefy
Harington, Eastern Washington
Either a bad element or wire issue. I would say your testing is proper, thats what I would do.
They are pretty simple. I wouldn't normally expect it to fail so quickly, but things are pretty cheap these days.
Can you follow the cord to the heater? Maybe a rodent chewed the wire, or some ice buildup caused it to come unplugged.
lilredex
Toronto
When I needed a block heater in 40 below weather, I'd plug it in for an hour or so and then touch the block.........if it was still stone cold, it ain't workin'.
nadogail
Coronado, CA
If the heater were plugged in and tested dry without a load to carry away the heat the test may have destroyed the heater.
R
Ramper
Southern MN
I ordered a new one. School is going to install it. Any way to know if the unit was bad or ruined by running it dry?
u2slow
BC
They're usually visibly burnt/damaged if run dry (overheated).
If it didn't work from new, it should still look like new.
