blower wheel replacement 5/16 inch shaft?
sdowney717
Looking for a replacement for a plastic blower but could use metal also.
It measure across the base 4.25 inch and height 2.5 inch and shaft is 5/6 inch.
motor shaft has a flat spot to key the wheel.
So two questions,
does this new one have a 5/16 inch shaft?
when I measure my wheel, the base is 4.25 and the top ridge 4.5 inch,
I suppose the 4.25 inch wheel is the right size?
http://www.google.com/products/cata...=X&ei=K1GMTr_qDobMsQKrn5WxBA&ved=0CIIBEPMCMAQ
here is their wheel
n8_jwf65dSDYPHMwY1gstvtPSkc0TjQOmUNPZzCX2SNLdYWGMQuBeiYQ5z1Iz0PmBDJKgGpIVuar7AMYYGuyiv_xM-hPYZq4Vcxqo1-v8Imf-O01SgNXgVTkzYp59UZyWuQMBhjabdD5ShFo12aJ0l-aGwPEXCC4xsgOsljb0g
here is mine. Reading the numbers says it is made by Mamco Corp
sdowney717
called grainger and shaft size is 1/2 inch
I suppose perhaps hole could be bushed out??
I ordered it as Mamco Corp no longer makes these parts.
So I need to bush this to get a 5/16 inch shaft
I found some spacers at McMaster Carr. They sell a bronze spacer 1/2 Od and 1/4 ID so I would have to drill it out. They also have bearing bushings.
http://www.mcmaster.com/#unthreaded-spacers/=ecy2xb
spy604
look on mcmaster for sleeve bearings or drill bushings, either could work and come in the sizes you need.
sdowney717
Thanks saw that at McMaster-Carr.
I found a brass sleeve spacer, it has 1/2 OD, 1/4 ID which I will have to drill out for the shaft, then drill a sideways hole for setscrew.
http://www.mcmaster.com/#unthreaded-spacers/=ecys4b
Do they sell a bearing sleeve bushing I dont have to drill out?
actually, they do,
1/2" 1" 6391K443 1.40 9368T126 1.60 2868T69 1.42
Catalog Page|Bookmark
SAE 841 Bronze Sleeve Bearing for 5/16" Shaft Diameter, 1/2" OD, 1" Length
Bearing Tolerance Information
sae 841 sae 863 what is the diff?
kbs2244
That sure looks like the replacement blower wheel I put in my clothes dryer.
I don’t know the specifications, but you might want to check.
sdowney717
wow that is the exact part size.
I wonder what that costs
sdowney717
well its all together and working fine with the bushing.
picture of new galvanized wheel with bushing and reassembled blower.
it pushes out a lot of air.
the bushing was easy to drill the hole in the side. I slightly filed outside of bushing to make it slide in easier. Basically press it in, mark with setscrew, press it out drill 5/16 hole.
hardest thing was lining up the hole in the bushing with the setscrew. setscrew is hardened steel and bushing is soft so it worked going together slighly forcing the setscrew thru the drilled hole as the edge was a tiny bit off..
