ProGun3400
Lincoln Bearing Packers Other Tools (Reduced)
Blue Point Inductive Ammeter Set MT1009 which consists of the alternator current indicator and the starter current indicator. These are unused in the box with instructions. The box shows wear from riding in the toolbox for all these years but the gages are in new/unsed condition. $40.00 Sold USPS money order plus actual shipping.
Also available, a few bench mountable wheel bearing packers. The large one I've used three or four times. It works great just a PIA cleaning up and putting in my box after every use so it doesn't sprout legs. It's designed to be mounted to a bench with a 1/2" pipe flange.
Used. Like New (Left Pic.)
Lincoln Industrial (LIN102891) Bearing Packer - Head Only Bearing packer head for bench mounting. Services bearings 1-3/4" to 9-1/2" OD. Accepts grease through fitting from high-pressure control valve or hand gun. For bench mounting, use 1/2" pipe flange. $95.00 Shipped Con US Only USPS Money Order Only
New, Unused (Right Pic.)
Lincoln 816 Wheel Bearing Packer Services bearings with 5/8" to 1-1/2" I.D. This versatile, compact unit mounts on work-bench or wall. Bearing is flushed and packed by contacting fitting in packer head with power gun control valve or by high-pressure hand gun. Overall dimension: 41/2" high, 4" wide. $65.00 Shipped Con US Only USPS Money Order Only
