rishavrastogi
Hi, all!
So we came up with the BluBird and Oil-Shield hoses and you folks at GJ really helped us out with the beta tests. And now we are back with another cutting-edge product. The BluShield All-Rubber Kevlar-braided Pressure Washer Hose 4000PSI. So what's special about it?
You find two kinds of 4000PSI 3/8" pressure washer hoses on the market:
1. Single Wire-braided (3-ply) hoses (Rubber and plastic)
2. Double yarn-braided (5-ply) hoses (Rubber and plastic)
Both these have issues of being heavy and having flexibility / memory issues, which makes them hard to work with and manoeuver around the space.
The plastic ones are of course not as heavy-duty and don't support hot water.
With BluShield, we are bringing the same BluBird design philosophy of being light, flexible and easy to heavy-duty pressure washer hoses.
By using kevlar/aramid (yes, the bulletproof material), we can make a hose as strong or even stronger than steel braided hoses in a single-braid.
And that makes our hoses 30% lighter while still being rubber and much more flexible and easy to work with.
1. 30% lighter than similar performance rubber pressure washer hoses
2. Much more flexible than wire braided or double-yarn braided hoses
3. Supports hot water up to 200F
3. 100% Rubber Tube with RMA Class A Oil-Resistance
4. 100% Light-blue Rubber Cover with high abrasion resistance
5. Kevlar/Aramid braided single-braid reinforcement stronger than wire
6. 4000 PSI Working Pressure with a 4:1 Safety Factor
7. Good cold weather flexibility, much better than plastic / PVC hoses
8. Available in both conductive and non-conductive designs (wire ones can't be non-conductive)
We can call it bulletproof, but we won't. And we want to put our claims to test. Our in-house testing that has lasted a year or so has proven great. And now it is time for you, the users, to put these to test.
We are giving away 5 units in the first batch on a first-come, first-serve basis. So, please apply with a line or so about how you intend to use it and why you think you'd be a great beta test case.
For any queries, you can reach us at [email protected]
Thanks!
Best
Rishav
Thanks!
Best
Rishav
