Boiler Fluid Level - Here comes Winter!
mnwebb
St.Paul, MN
Hey all - How often should I check my in-floor boiler fluid level? There's a tiny leak (not even enough to drip down) at the top of the boiler but besides that everything seems good and it holds pressure. I'm about to fire it up for the season but should I check the level and re-pressureize the system? Any other regular maintenance you would do? It's electric, fyi. Thank you!
fitter30
Peace Valley,mo
Any leaks need to be addressed. Make water brings with it oxygen which is bad for the system and if there's any glycol its diluting it. 10 lbs is more than enough pressure and expansion tank bladder needs to be at the same pressure with boiler and pumps off system 100° or less.
