Bolting 44" HF Tool Boxes Together
black00lightning
TX Hill Country
I have 3 Hf boxes I want to bolt together and I assume I use the 2 rivnuts on the side bottom. I can see how one could do it with the boxes laying on their backs. How can I do it with upright and casters bolted on? Thanks.
kctyphoon
Jersey/Staten Island
Can't you just remove the drawers and drill some holes through the sides, add short botls/nuts ?
In some other treads, guys have built a frame out of angle iron for the boxes to sit in/on, and added casters to the bottom of the custom frame they built..
black00lightning
TX Hill Country
I've thought about drilling through the sides but concluded that using the rivnuts would be much stronger. Welding up a frame is in the plan but down the road. Trying to get them setup together till then. If I can't figure out how to do it, I may drill the sides.
kctyphoon
If you just want something quick and dirty - how about a 2 long pieces of 1/2" steel black pipe and two sets of those pony clamps that slide onto the pipe.. Stretch a clamp across the front and back bottom ledges, or underneath the cabinets, and just give it some moderate pressure.. No damage to the boxes either.. Just a thought, probably won't work without clamping the tops together if you need to roll them around though....
bmwpowere36m3
I can't see using the rivnuts…. those are likely there for side cabinets/lockers and/or handles. Pull a few draws out, drill some holes and bolt them together. Doubt you'll be able to roll them around, unless you build a frame on its own castors.
black00lightning
TX Hill Country
That may be my only option, drill the holes. As far as rolling the cabinets, I drilled and tapped new holes to move the swivel caster to the front of the cabinet. Hopefully I'll be able to roll them away from the wall for clean out.
racinfarmer
Minnesota/Utah
If you have plans to make a subframe for them, why waste the time and effort of bolting them together? Just line them up and build the frame in the next week or two.
black00lightning
TX Hill Country
I'm trying to do something sort of temporary. It'll be at least 6 months before I am able to work on the platform. Too many other higher priorities. We moved into a new house recently and a lot of honey-do's on my list.
fury9
Mchenry, IlLaHnoYs
Highly unlikely the riv-nuts will even line up, they have a hard enough time putting them in the right spot for the handle
astroracer
Mid_Michigan
Just wondering WHY they have to bolted together right now?... What are you doing that makes this a priority that can't wait till you build the frame...?
Mark
Rlfd213
The rivnuts will not hold them together. Take a couple drawers out and drill holes. Take a 1/8 or 1/4 piece of steel and put it on each side and then bolt the boxes together. The steel will capture the stress. Just make sure it's 1 piece of steel for all the holes.
bcradio
New Mexico
Am I missing something? Use the existing holes and bolt them together... that's what I did
NUTTSGT
Northern Central Ohio
Can you pull the axle bolt out of the caster, insert a section of all thread (or make your own long axle rod) and through bolt a pair of casters together ?
They won't swivel but the should pull straight out for cleaning.
taumac
Brooksville, Fl
That's my thought too. Of course you'll need to drill out threads on one side.
My thought is to keep them as they came and just put finish top on it. If want to key them together take I piece of ply and cut it to fit inside the recessed top then screw finish top to that.
yamaha0343
South Louisiana
Mark
I agree, just lock the casters for right now until you have time to do it right. The riv-nuts won't hold up if you try to move that behemoth.
On the upside, congrats on the massive storage. :beer:
cheechi
Triad, NC
The casters are too close to each other to bolt them directly. Unless you got a 7 drawer side box for each pair to bolt to, you really can't bolt them directly without removing some wheels.
Steevo bench is the best idea. Second best is wedge a 2x4 between each and use the bolt holes to put a through bolt smaller than the threads and just make it as tight as you need and don't move them around too much.
kkroger
OK I'll be "That" guy, cover the end of one cabinet with 3M VHB (it comes up to 48" wide) then peel and stick.... :D
monkeyspanners
Oxford, UK
Could you make and fit a sandwich plate between the castor and cabinet that spans the gap, using the castors bolt holes? You'd need to pack the end castors the same thickness. It would leave the cabinets unmarked should you wish to split them in future.
kkroger
A connector plate to span the seam and bolt to the caster points with a single caster in the middle of it... then some re-inforcing plates where you bolt the cabinets together.
