Bosch new 36v 1/2" driver drill kit-$165
cartotem
Here is a deal for you guys. Brand new, never used. These sell like hotcakes for $200 on Ebay, list is $485. I'll let this one go for $175 delivered. Made in Switzerland
BOSCH'S BEST, TOP-OF-THE-LINE 36 VOLT CORDLESS Brute Tough™ 1/2" DRIVER DRILL CORDLESS TOOL KIT WITH TWO Litheon™ SLIM PACK BATTERIES, CASE & CHARGER! Model 38636-01
PROFESSIONAL TOOL FEATURES AND SPECIFICATIONS:
• Litheon™ 36V batteries – Up to 5 times more charges than competitive lithium-ion batteries.
• Brute Tough™ Construction with Unibody Powertrain, Metal-Reinforced Collar and Durashield™ Housing
• High torque mode produces over 600 in.-lbs.
• Externally Accessible Brushes - For brush replacement in as little as 2 minutes
• Ratcheting, Carbide Tooth Single Sleeve 1/2" Chuck – For one-handed bit changes
• Bosch Designed Powertrain with Metal Gears
• 15-Position Clutch
• Litheon Fast Charger - Charges 36V batteries to 80% of capacity in 30 minutes
• Flexible Power System - Match battery to application. Slimpack 2 Included) for 36 volt power, at 14.4V weight.
SPECIFICATIONS:
Voltage: 36V
No Load RPM: 0 - 960 / 0 - 1,500
Torque: 600 in./lbs.
Weight with SlimPack Battery: 5.6 lbs.
INCLUDES:
(2) Bosch 36V 1.3 Ah Litheon Lithium-Ion SlimPack Batteries - BAT818
Bosch 36V 1-Hour Battery Charger - BC830
Double-ended Bit
Carrying Case
C
cartotem
Yea, I do have the model number correct. It looks like the retailers are making up a number for the MSRP. I just did another search, and found it as high as $752.00 for the same kit. Sorry about that. I just looked it up once the first time. Here are links to several that show the wide span of pricing. You still can't beat my price.
http://www.iliketools.com/hardwares...=39/c_ID=193/productID=629/store=Bosch3863601
http://www.wigix.com/item/2022549/BOSCH-36V-Bosch-Brute-Tough-1-2-Drill-Driver----Model-38636-01
http://www.ohyeah.com/toolsv2_interface/OHYEAH-Current-List 10-02-08.htm
sti491
Greensboro, NC
I didn't mean that your price was a bad deal. Sorry if it sounded that way. Actually, I think your price is good.
I'm looking more for a heavy duty impact gun. I kinda misread your post the first time.
comedyman809
Smithtown, NY-thats in suffolk county long island.
i own this 36v bosch, and ill let all people interested in it know, that this is by far the most powerful cordless hammer drill/driver i have ever used.
i put holes in concrete no problem, as for using it as a regular drill/driver, best i ever used also,
just to let all know, it is a littler heavier and bulkier than the 18v models, but it lasts a very long time even under heavy loads.
