Hey Guys,
First post on the GJ - been on the JJ for years...
I have a 20 Ton Jack - of unknown origin or age. I've had it around 10 years or so. I used it the other day, and afterwards I noticed it was sitting in a pool of fluid. I wiped it all down, and watched, and it is leaking around the outer perimeter of the stamped steel canister - the resovior I guess - and the cast base. From what I understand, this is not a pressure bearing seal area.
I searched online for a bit trying to find a good exploded view, with not much luck. I'm looking for some info on how that comes apart - Does the outer body (4" diameter) thread into the cast base? Is it pinched down by the large nut around the ram at the top?
Thanks in advance -
Thanks in advance -
