Does anyone have any experience fixing generators or diagnosing the case of a problem?
I have a BS1550 porter cable 5500 watt generator with a briggs and stratton 10 hp engine. It works somewhat well with small loads, but after a few hours the voltage starts to drift up. If I put a big load on it, like my well pump kicking on, then the genrator slows way down and the voltage drops. I can manually pull on the rod to the carb and it speeds up and increases the voltage. I am able to keep the voltage in the right range by looking at the multimeter i connected to it and can get water pumped to fill a bathtub. Would like to see it do this automatically.
I pulled the generator and popped open the crankshaft housing and found the governor gear was broken. I replaced that. but it looks like there is another problem. Voltage regulator bad? Not sure.
Anyone have any ideas for me?
