Budget friendly engine support bar
Ohmthis
Outside of Louisville KY
I’m going to be replacing the transmission on my GMC Acadia very soon. I need to support the engine from the top while I remove the subframe. I have a lift so the vehicle will be moving and an engine hoist won’t do. I did a quick search, but the vevor option didn’t make me feel all warm and fuzzy. Is there another option that is recommended? I don’t have particular price in mind, but I will be getting under this car and don’t want to be a story. Thanks all!
bwringer
Indianapolis
Agreed -- the Harbor Freight version is well-built and quite strong. It's not a space shuttle or a Rolex.
However, get out there with a tape measure, ponder where the "feet" will need to land, and make sure it will be wide enough. The HF bar is 58 inches long, and I learned the hard way that it wasn't long enough for my minivan. YMMV.
N8sToolz
Have definitely made my own before out of squared tubing and angle iron before.
Sunex has a pretty affordable one too that I use.
Edit Sunex 5207
O
Ohmthis
I have thought about that. I’ll need to measure the dimensions and make sure they will work for me. Thanks!
dogdog
other than three point support vs two point support........ assuming no body lies, how do you determine beef?
Engine Support Bar, Steel, 700 lb.​
  • Lifting Capacity 700 lb
PITTSBURGH AUTOMOTIVE 1000 lb. Capacity Engine Support Bar​
Support bar with a 1000 lb. capacity
Firebrick43
West central Indiana
Its a 4 banger or light V6. A pair of scrap 2x6 glued together with some 1/2" ply blocks between them at the ends and middle will allow some all thread rod to slide to a position where you need them to lift the engine.
They would support 1300 pounds conservatively with a L/240 deflection of 0.25" @ 60 inches.
paulsomlo
Northern Colorado
Visual inspection - and I trust OTC's capacity claims over those of Harbor Freight.
dogdog
It’s not just hf even the otc straight bar style support that looks exactly like the hf unit have the same or similar capacity of 1000 lbs as oppose to these tri finger ones that only claims 700lbs
Anyways thought there is an insight to the differences.
***Btw there is no Welding on these two bar supports, maybe other than the end caps which doesn’t technically count.
paulsomlo
Northern Colorado
You got me - at any rate, I'm glad I bought the one I did when I did; because I think I paid about half that.
will335i
IL
Another vote for the HF one. I used mine when I was doing some work on my BMW. As long as the length is good it should do what you need it to do.
BikeRider
Queens, NYC
Does anyone know where or how to get spare parts for these? I bought a used one from Amazon that was missing one of the hook screws and both chains. I was going to return it but they told me to keep it for free. Alternately, what could I get to jerry-rig the equivalent that could support a comparable weight?
nicks78camaro
Pittsburgh, PA
Rural King or a local hardware store
BikeRider
Queens, NYC
If it is identical, look up the harbor freight manual and see if their parts website has them available
I checked, not available. And even if it was, experience tells me that it would near the cost of a new support bar. I'm just looking to find a functionally equivalent DIY solution that would be safe and not too expensive. Are there relatively thick threaded rods than end in a pair of strong hooks, or perhaps hooks that you can thread onto a threaded rod, with a matching threaded handle for the top part?
I'll probably end up doing what I usually do, walk through a local HD or Lowes until I find parts that look like they'd work, even if they're not necessarily intended for this application.
joshmodelskidoo
mid western michigan
Pulled the trans on our 2012 traverse and started with a cherry picker but it was a pain to work around and very discouraging. I ended up with a 4x4 and 2 ratchet straps.
nicks78camaro
Pittsburgh, PA
5/16" grade 30 chain has a working load limit of 1900lb, more than enough for your application.
As far as the hooks, something like this with a high working load limit. Normal j bolts you get from the hardware store may have a much lower rating.
Or maybe just loop the chain over and bolt it straight to the bar itself.
