Build Thread - 69 Bronco
bulletpruf
San Antonio
Have been working on my '72 Javelin 24 Hours of Lemons build, but will get back on the Bronco soon. I have two original Bronco 3.03 3 speed manual transmissions that I brought home from the shop. I'll rebuild one of those in the near future. Once that's done, I'll get started on the budget friendly 302 rebuild - just a stock'ish bottom end with some GT40P heads.
PhantomEB
Medicine Hat, AB, Canuckistan
It runs as is, I just need to bleed brakes and weld up the angle bracket for my shifter then I think I good to go for around town. Need to hook up the triple stick as well before skidplate gets bolted up which she’s good for the trails. Lots of details like lights for this and that plus a rack for over the batteries and fuel cell are on the list.
bulletpruf
San Antonio
Working the 3 speed RAT transmission and it's been fun. The Bronco trans is slightly different than the passenger car trans, there are no YouTube videos of a Bronco trans rebuild, and the Shop Manual is not a model of clarity. But I got it apart.
I disassembled the cluster gear after I took this picture.
Rebuild kit from USA Standard Gear has plastic thrust washers. You've got to be kidding me. I am going to reuse the thrust washers for the counter gear; they're very nice. For the reverse idler, I found some NOS ones.
Now I need to find or make a dummy shaft for the counter gear shaft - .865" x 5.070". If I had a parts trans, I could just cut one down, but I don't have a parts transmission.
While I'm waiting on that, I'll work on reassembly. Will try to get the cluster gear reassembled before I start work today.
WoodsTruck
What kind of shape are the syncros in?
Mine shifted very fast but the main bearings started having a ton of slop in them. It would pop out of 3rd when going over a hill at highway speed going from power to coast. Had it gone through with another box and swapped parts (poor college student at the time) and it held in 3rd, but would pop out of 1st instead. Not quite the ideal trade off going down the driveway at my folks' place.
bulletpruf
San Antonio
Synchros and gears are actually nice. I’m replacing the synchros but I think it would have been fine if I reused the original ones.
