It absolutely does make a difference with A or B that describes the pattern of the nozzle. The numerical designation is btu equivalent. 140,000btu / gal of oilX .85 or .75= net input. The 75 will likely be ok BUT you need the filter replaced, the chamber cleaned and the combustion set up properly to get the right bang for your buck. It pains me to say this as I was on the NFPA 31 Committee for 15 yrs, but oil is about the most expensive heat you can have today. I had a lot of oil folks add mini-split heat pumps and see savings of 70% over oil.
