Richard D
Electricity is such a mystery to me I have no idea how to do a search on this. I want to locate my machine about 30' from my fuse box. What size cable should I run in the wall?
When I read posts like this my first and only instinct is to say call an electrician.Electricity is such a mystery to me I have no idea how to do a search on this. I want to locate my machine about 30' from my fuse box. What size cable should I run in the wall?
Install 6 gauge individual travelers. Put a 50 amp breaker in the panel and 50 amp 3 wire outlet at the box. Change the plug on your Miller to a 50 amp 3 prong (if not already there) and jumper it for 230v service.
I was wondering what he was talking about, I thought he was being facetious.So much wrong with this! Why would the OP waste money on #6 wire when his welder doesnt even pull 15a @ 240v? And how would jumpering the terminals in the outlet give 240v? What u are recommending is a waste of money and makes it more complicated than it has to be!
Oh, I agree. It's just I am SO done with giving people advice who are blatantly and obviously over their heads. There ARE times when "call a pro" is the ONLY answer. At least the only answer I am comfortable providing.Agreed BUT people these days want to do things themselves despite the inherent dangers involved because of lack of knowledge or skill!
I agree again!So much wrong with this! Why would the OP waste money on #6 wire when his welder doesnt even pull 15a @ 240v? And how would jumpering the terminals in the outlet give 240v? What u are recommending is a waste of money and makes it more complicated than it has to be!
Is this the type cable I would need?
http://www.wireandcabletogo.com/6-AWG-THHN-Building-Wire.html?
Two separate cables? Or a third for the ground?
O.K. so 10/3 should do it. I don't see myself ever getting a bigger welder, I've had mine for many years and it has always been more than enough for my needs. Thanks for all the responses.
Yep, now you have enough power and a safe wire size for another welding machine. It will cover future purchases too.
I agree, but this will be in a semi-outdoor location. All my other powertools(except grinders/wood cutting circular saw)are inside the A/C equipped garage. Really gotta get it done on the cheap. If I ever do, in years to come, get something requiring power that heavy, and mount it outside, I'll just pop for new wire.BD1, thank you for helping point out the obvious.
6 gauge stranded wire is about a $1 a foot. Yeah, it might cost you $125-$150 to set this up but you'll have plenty of power if you decide to purchase equipment that requires it down the road.....You can't have too much power available.
There is no ground. You'll have two hot leads and one neutral. That neutral effectively is your ground as it is ultimately 'grounded' at the main breaker panel.
