Can anyone I.D. this compressor?
TheEuronater
Philly
I know this is a long shot, and the pictures are bad but I know some of you know these things with your eyes closed. My teacher is actually selling it for the school but I haven't seen it in person, and the auction ends tomorrow morning. I asked him for the name but he didnt know. Thanks!
Edit: How much would a 2 stage of this size be worth? I dont want to over pay
Brad J.
Not sure but it isn't a Quincy, Saylor Beall, Champion, or Kellogge American.
My guess is ingersoll Rand by the color and head but it's just a guess.
redmondjp
Redmond, WA
That's not a two-stage unit. That looks like a twin HVAC control system compressor with the alternator controls (runs one pump, then the other). It's single-stage, and probably set up for 80-100psi range. And it's got 3-phase motors on it.
I'm thinking maybe Devilbiss on the pump.
What do you intend to do with it?
MacMcMacmac
canada
It's a duplex DeVilbiss 220 setup for HVAC controls. Probably has a Honeywell, Powers or Johnson Controls sticker on it somewhere. They are single stage pumps. and being an HVAC unit, may have undersized motors good enough to get up to 60-80 psi and not much more. Have a good look at it before you pull the trigger. Even at full chat you are only getting about 2hp worth of air out of that, so unless your air needs are pretty modest, I'd pass.
T
TheEuronater
Philly
Thanks for the help!
I wanted to use it for just general shop use, but I guess that's out of the picture! I have another compressor, but if this one is a good enough deal then I would want it if theres a way I could use it.
This is why I come here for the help! I really appreciate it. Here's another picture just for the hell of it
MacMcMacmac
canada
Ok, I see the Honeywell sticker on the side, heh.
Actually, I am reconsidering some of my earlier remarks. If you aren't dreaming of sandblasting or using air hogs like sanders or die grinders, this would be an awesome general use compressor for the home, IF, it is not all three-phase. That would knock a big hole in its desirability. 2hp is actually plenty of air for most people. You would need to wire it up to get both pumps running at the same time, but that's not a big deal. It would max out around 120psi. These are well built compressors. I forget sometimes that not everyone is looking to do blasting work 8 hrs a day, and generations of men have happily run all their stuff on 2hp or less.
T
TheEuronater
Philly
Great information! Do you know how much these type of compressors usually go for? I know there's a lot of ifs because there isn't a ton of info on it. I wouldn't want to overpay if I could possibly get something better for the same price. Thanks!
redmondjp
Redmond, WA
Price? Anywhere from free to way too much! Once you figure out what the pump is, you can get its specifications to figure out how fast you can spin it, how much flow it can output, and what HP will be required to get that pressure/flow.
Here is one thought - if you set up the pumps to spin at a speed that requires a maximum of 2.5HP each, you can obtain a single 5HP electric motor with a double-groove pulley on it, and drive both pumps simultaneously (you will have to slot the mounting holes on one pump so you can tighten its belt).
If the pumps are large enough that you can spin them a bit faster which will require maybe 3-3.5HP each, you can step up to a 7.5HP motor ($$$) and do the same (that's about the maximum amount of HP you can run through a single belt).
So price, again? First the motor: New, you're going to be looking at $350-500+ for a 5HP motor, or $500-800+ for a 7.5HP one. Used motors will be less of course, but I don't know how easily-obtained they are in your area.
Then, you'll probably have $80 in a sheave/pulley + belts, along with $30-50 for another pressure switch having a higher operating range. Another $50 in fittings and misc. hardware. Oh, and then motor starter - that can range from $50-400, depending upon quality/type (IEC vs. NEMA), new/used, and how big your motor ends up being.
Plus your time. Add more time and $ if you have to rebuild one or both of those pumps. Not trying to scare you away from this, but this is NOT a turnkey setup by any means.
Speaking for myself, if I could see the unit, verify that both pumps have a good oil level in them and that the oil looks like clean motor oil and not like a mocha, and that the tank is mostly oil-free, and both heads make the chuffa-chuffa-errk sound when you rotate them by hand, I'd probably pay up to $150-200 for it tops. Oh, and then there is the tank - if it never got drained, it could be shot. Deduct $250 if a gallon or more water comes out when you go to drain it.
This is getting long-winded, but hopefully will give you the factors to consider in your decision. Maybe others can chime in on parts availability for that old of a Devilbiss pump - I want to say it shouldn't be a problem but I don't know that for sure.
