Cleaning Epoxy Floor
scott750
Austin, TX
What products and methods do you recommend for cleaning my epoxy floor? I read the dish soap us nit recommended because it can leave a film behind. I have some dirt build up from dirty water dripped off of the cars.
Sent from my Verizon Samsung Galaxy Note 2
Falcon67
Merkel, TX
I use a regular string mop and some industiral cleaner from Sams. Works well. I also spot clean with Simple Green.
Macgyver_ga
Canton, GA
Here's my cleaning steps.
-Lightly spray it with the hose to get it wet
-Dish soap and scrub brush to clean it
-Rinse it out with the hose
-Squeegee it
-Mop it with a string mop and straight water to remove any remaining soap residue.
Shea
California
For standard cleaning I've always used about 1 cup to a gallon of water in a bucket. Stubborn stuff might require a stronger mix.
bd8134
Franklin, MA
I use a Hoover FloorMate with pretty good results using hot water and their detergent. I have not noticed a residue, I use the dry setting to **** up what water is left.
Once in a while I use a pressure washer with a cleaner solution. A bit more mess and I need to move everything out.
If parts are more difficult to remove, I use a stiff short haired broom using the Floormate detergent.
