Clear garage floor coating systems
ROBZ71LM7
Louisville, KY
I've got a new house and garage. The new garage is bare concrete, 5 years old, and really clean. What I would like in lieu of a color epoxy or coating is a clear coating that is chemical resistant and adds a satin or semi-gloss shine to the floor. What are my options? I've got 1,000 sqft to coat and would like to keep it under $1,500.
Garage Flooring
Grand Junction, CO
I would suggest clear polyurea. The single coat would require 5 gallons. 2 coats 10 gallons. $679 for one coat. https://www.garageflooringllc.com/polyurea-garage-floor-coating/
I would suggest adding 3-5 lbs of antiskid
72Camaro
Tejas
Will these coating hold up to chemicals as well as welding sparks and hot slag from torches?
RPH
Michigan Thumb
Ghost shield 4500 with the 8510 sealer. It penetrates the concrete so no real color change. It’s uv resistant, extremely tolerant for chemicals. And is one of the cheaper systems to install.
There is an ad in the classified now for a volume at $450.
PhilJohn
Minnesota
FJ4FUN
NorCal
A generous coat of Wolverine Coatings BondTite 1101 followed by their EnduraShield 2254 would fill the bill nicely... As previously noted, protecting from welding slag is recommended.
Armorpoxy
We would recommend our one part SPGX Polyurea which would be under $1,000. Easy to apply and non yellowing.
