Code for wiring Dusk to Dawn light?
rodm1
I have a MV light with extension arm that I'm going to replace and would like to run new wire and update to code. Any one have photos of a code compliant install or a link to installation instructions?
The current install has romex running threw the extension arm with drip leg then into a steel junction box into building. I'm assuming I would need (NMC, NMW or UF) cable? Because the drip leg would be exposed and some kind of water tight junction box?
http://www.stonco.com/uploads/products/DusktoDawn.png
pattenp
Virginia - USA
UF and water tight box is what you should use.
