"code" info here
Mr_fixit
Rustylvania
Here's a couple good sources for info, but be warned the first one does not like do it yourselfers. You may learn there that licensed electricians have a very high opinion of themselves. So read all you want, but ask intelligent questions, or not at all.
http://forums.mikeholt.com/
Another
http://www.electrical-contractor.net/forums/ubbthreads.php
The next is the actual NEC code.... might be second newest one anyway.
http://www.nfpa.org/categoryList.asp?categoryID=279 I can't remember how you get to see it, You can look, but cannot print. I know you need to log on and agree to terms, but I can't remember the rest. I have it bookmarked at work, so I'll try to get more info. Or maybe someone else can fill in the blanks...
And here's some calculators...
http://www.electrician2.com/calculators/elcal.html
I didn't get to check out all of this one yet,.....TIPS.......
http://www.codebookcity.com/codearticles/nec/index.htm
trainer
Northern Ontario, Canada
Found a good local link for wiring and what not.. Its for my city but i bet its close to the same for most places
http://www.winnipeg.ca/ppd/pdf_files/D_Garage.pdf
http://www.winnipeg.ca/ppd/pdf_files/HOElec.pdf
Wow. the minimum structural requirement for walls there seems pretty skimpy....2x3's on 16 inch centre for 8' high walls or 2x4's on 24" centre for 10' high. I built mine with 2x6's on 16".
When a building with truss roof fails due to snow load, it's usually the walls that give out.
