Comfortzone 220v heater issue
ebarker9
I've had a ComfortZone CZ220 heater in my 2 car garage for the past 3 years. It's always worked well with no issues until this evening. I was letting the garage warm up for about 20 minutes and came out to a strong smell of electrical components burning. After letting it cool down, I took a look at the wiring and everything on the L1 side of the connection block was melted. I'm using 10/2 Romex going to a 30a breaker which didn't trip. Having a hard time figuring what the issue could have been...interested in any thoughts. Mostly grateful that I was around to catch the issue before a fire started.
Bert_
NW Iowa
Either the factory crimp on that black wire wasn't tight. Or you didn't get the screw tight on your wire connected to L1.
E
ebarker9
I'd assume the latter is more likely although it seemed pretty tight when I removed it. Definitely will approach replacement with an abundance of caution...
The Cobbler
I would think that since the line wire is melted, that was the bad connection. if it was the factory crimp on the heater side, that would have melted . (unless of course it is a higher temp rated wire maybe
E
ebarker9
^X2
since the wire past the connector isin't melted, and only melted at that point, it was a bad connection
Thank you. What didn't even occur to me at the time and I may now be kicking myself for is the use of stranded wire between the junction box and the heater...used a "Liquid Tight" extension because it allowed some flexibility, but is it inherently problematic to use that with a screw terminal?
Bert_
NW Iowa
That terminal is almost certainly rated for stranded wire. Stranded wire was not your issue.
E
ebarker9
:wtf:
Is it worth considering using a crimped ferrule when I install the replacement? I know it's completely possible to get a solid connection without, but given the past issue I'd rather reduce the risk as much as possible.
