comp air filter / dryer unit info help .
sweetk30
finger lakes area upstate ,ny
anyone seen one or know were to get replacement guts ?
and or is it even worth it to redo it ?
has a tag
HI-N-DRY
compressed air filter/dryer
by filenco
filter engineering co inc boston mass .
she is heavy cast aluminum with 3 1" pipe thread ports in/out/drain .
the top is aluminum with oring seal and V-band clamp .
gamescastspencer
Saint Peters, MO
If i recall the guts for some are white cubes, about the size of a sugar cube. Not sure where to get them though. I would say it would be worth it to get parts for it.
Sent from my D6708 using Tapatalk
md21722
Mt Juliet, TN
That looks as old as Moses. I would just throw it on the scrap pile and invest in something made in the last 40 years.
bsaint
Manchester, CT
Super easy to replace. If you can find some sort of mesh sock and fill it with desiccant beads, you're all set.
pcmeiners
Great find....
As Bsaint states a sock will do, or mesh bag of synthetic fiber. You have a real desiccant dryer, not a wannabe (1 cup of desiccant) drier. Please note this will not take care of all the air your compressor produces. A compressor aftercooler and this would produce some really dry air. If you were to use this in a humid area, like NYC in the summer, alone, you would probably get 6 hours of heavy spray gun use before it needed regeneration. You have the equivalent of a drier costing hundreds, by all means if you want to "throw it on the scrap pile ", send it to me, I already have one about 8 times its capacity, but I could use another.
bsaint
Manchester, CT
Im actually building my own air drier. I did all the math at work last week (it was slow) just gotta buy the supplies. I calculated it would need a regen every 8 hours of air running through it at 10cfm and 150 psi with a really humid day and without an aftercooler. Im going to try and figure out how to make a mini hot air purge at 250*F. Also I have a flow switch in my box of junk so it will only purge and regen every 8 hours of air running through it, not every 8 hours.
