Compressor outlet? box?
Y
ynned
N.E. Ohio
yeah, the receptacle is rated 20a, so I can't go bigger than that. I just wondered about 20 being too much for the cord.
strutaeng
Dallas, TX
If it comes factory with the 20 plug it needs 12 wire and a 20 breaker.
That's what I would do. That's a very nice compressor. Too bad they are not as common as they used to be. It has some decent CFM for doing real work AND it's portable (well, "movable.")
Y
ynned
N.E. Ohio
Yeah, I had to do some looking and driving for it. I didn't want one of the popular 60 gal stationary because I want it under a corner cabinet which is too low for the 60 gal. Puma makes a 40 gal vertical which would fit, but it's more money, and had to be shipped for another hundred bucks or more. Surprisingly, I found the best price at Summit racing, and it was in stock and only an hour from home.
Y
ynned
N.E. Ohio
The question was can I run a 15.7 A rated motor with a 14 ga cord on a 20 A breaker, or should it be 15A. I'm gonna put a 20A in.
The second question was do I leave the neutral (white) or the ground (green) unconnected to the receptacle. I'm gonna hook up the ground.
sberry
Brethren, Michigan
If it comes factory u can hook it to 20,, the motor has its own thermal, it actually protects the wire ahead of it. Yes, use the ground and cap the neutral.
You plug 16 wires in to 20A circuits every day.
