Hi all,
I was wondering if any knowledgeable compressor folks could help me with a project I'm working on.
I recently purchased an old 5hp 220v 2-stage compressor mounted on a horizontal 80 gallon tank. The tank appeared to be pretty beat up and sounded suspect, so I located a decent used 60-gallon vertical tank. The problem is that the way that the pump and the motor on the old tank was spaced, I can't just move the motor and pump over to the new tank and maintain the same belt size. In fact, I'm pretty sure I can't mount the tank and motor on the new tank without having only 1" of clearance between the pump flywheel and the motor.
Spacing issues aside, I was wondering if the additional size/weight of the 2-stage pump and motor would be an issue on the smaller vertical tank, and if I did manage to mount the pump and motor, how I would go about getting a properly sized belt for the new setup. Would only having 1" clearance between the motor and the flywheel be an issue?
Any help/advice would be appreciated....
