Concrete floor paint..?
Bulldog13
Cape Coral ,FL
Had to do some repairs to my garage floor..I had a large crack that I had to fill with hydraulic cement.I was wondering if anybody has had any luck with concrete paint.I dont want to epoxy if the crack reopens...Thanks
thegarageguy
Its going to reopen regardless. Cracks need to be filled with a flexible resin. Also, concrete paint will not hold up to hot tires. You may find yourself more aggravated in the long run with a peeling floor and crumbled cracks.
Bulldog13
Cape Coral ,FL
I filled the hole with a 2 part epoxy, with a sort of foam rebar--I then filled the top layer with hydraulic cement after 24 hr.s---guess I should stay away from the cement paint.
