condensate pump maintenance
The Cobbler
Wow, never thought about condensate pump maintenance.
Mine split where the fitting for the discharge line enters the pump so I figured I would take it apart & crazy glue the crack in the housing. Inside the pump was eeewww, full of crappy sludge and smelled. never thought about an annual rinse & clean but it's on the list of things to do now.
Oh, and so far the crazy glue & baking soda is working on the leak ( crack)
Stuart in MN
Minneapolis
Yup, my furnace guy said they need to be flushed out periodically (And not just the pump and its reservoir, but also the tube from the pump to the drain.) They do get pretty scummy if you don't.
rlitman
Long Island
I like to use the "mints" in condensate drains to keep the drains clear, and would assume they stop buildup in the pumps as well.
MikeF2316
Thornhill, ON
We got a condensate pump back when we had A/C installed in the house just before the first summer. The furnace was a mid efficiency model and didn't need one. I've cleaned the pump a few times, it's always pretty gross but still works like new. Last summer I bought a spare, as it's been more than 25 years now.
naturalgas
Metrowest Ma.
I put a cup of bleach in reservoir and add enough water to bring pump on every now and then. Keeps the grime at bay.
Raisedonadeere
Central KY
My minisplit ceiling cassette has some sort of condensate pump but it is out of sight somewhere in the unit. It probably gets dirty just like the standard exterior HVAC ones. But I have not read or heard anything about it. This thread has me thinking “what else do I need to learn to keep these things over the long haul. Mine is starting its third year of full time operation.
Crazyjake8493
Upstate NY
If this condensate pump is on a furnace, I would also remove the condensate trap inside the furnace and flush that out as part of your yearly maintenance. Remove the trap, dump it out, fill with hot water, shake the **** out of it, and dump it out. If there's gunk in it, repeat this until the water comes out clean. You'd be surprised at the amount of crud, gunk, bugs, etc end up in there. While the trap is off, inspect and clean out the condensate hoses as well.
LS6 Tommy
Northern NJ
If the condensate pump is for a furnace, there has to be a neutralizer on the furnace drain before the pump.
Tommy
rlitman
Long Island
If thet condensate pump is for a furnace, there has to be a neutralizer on the furnace drain before the pump.
Tommy
There certainly should be. It's not anything real special. Just a bunch of limestone chips. You could make one yourself, though I like the see-through canisters, so you know when you need to refill.
bonneyman
Desert SW
After 25 years of cleaning condensate pumps every year, dealing with clogged P-traps, leaks, back-ups, etc. I stumbled upon a solution.
I found this used bottle of Goodwin's Pine Ammonia.
I remove and thoroughly clean the condensate pump pan. Re-install, and pour a cup of the green ammonia solution into the pump. What I started doing is once a month (during monsoon season when the unit makes a lot of condensate), I pour a cup of the solution through the P-trap - using one of the removeable caps - and allow it to run through all the piping into the pump.
Faithfully done, this will virtually stop slime build-up in the pump! Been doing it for several years on the home unit. Pump stays whisper clean!
When I used up that original bottle, I mixed up an alternative that I think approximates the formula. Mix 3 parts of Pine-Sol with 1 part household ammonia. I add a few drops of green food coloring to the mix so there's no confusion.
