Connector size question - mini-split
motterpaul
CA
I can't find the exact info I need to understand the types (male/female) and sizes of Mini-split connectors.
My micron gauge has 1/4" male flare connectors. So what other pieces do I need to set it up with a vacuum? Specially; what types of ends and sizes do I need for the adapters? I see some guys using two ball valves to isolate the micron gauge,
I have a 5/16 to 1/4" service port adaptor. I have a standard vacuum hose. I have a Schrader valve removal tool that is 5/16 to 1/4 with a ball valve. What kind of ball valve connector do I need and how do I add in the micron gauge?
I think the setup is like this - but I am not sure what I need to buy to add in the micron gauge:
motterpaul
CA
Please help if you know the answer - thanks. I can surmise that I know but I am tired of buying stuff that just isn't quite right.
motterpaul
CA
Thanks - I figured out (after watching 3 hours on YT) that the tech only uses an extra core removal adapter to isolate his micron gauge after the vacuum stage is finished. I should be fine connecting my gauge to the extra 1/4" outlet on the 5/16" to 1/4" ball valve that I already have during my vacuum. A good 1/4" to 1/4" VCRT is over $60.
jjrbus
Florida
Since I am a home owner hack, I see no reason for the extra shut off for the micron gauge. It is only to keep from cleaning
the gauge and having to clean it. That is after 8 hours on YT! If I were using it all the time it would make sense to add the shut off.
motterpaul
CA
Funny - we both obsessed over this and watched YT to figure it out. In the one "complete install" video the HVAC Pro guy actually says "this one is 5/16" and the other is 1/4". And he also says you don't actually need both, that it is just for convenience later on. But I was not going to watch that twice (although I did). Ridiculous how much a little thing like that can hang us up for so long.
jjrbus
Florida
I spend waaaay too much time researching, wish I could find a competent tech. Now I am trying to figure if I should use leak seal, some scream NO WAY NO HOW and others say they use it all the time? Who to believe although I am a bit biaesed against sealers in general.
motterpaul
CA
I'll tell you this. In MY research I find the older posts say "no way!!! (2015) but the newer ones (2021) are more comfortable with it. Rectoseal is well-liked and Pioneer recommended I try theirs, also. If you have a fairly clean and newer system, especially the coils around your fins, I would say I am not opposed to it. In an older system that may have a fragile set of coils I might not do it. Check your flares first with bubbles, with N2 if you can, but if you can't find it (because it is so small) you might try sealant.
jjrbus
Florida
I have found leak in evaporator coil with the Accutrak leak detector and verified with Calgon leak detector. I may have another leak but due to the shape of the coil I cannot verify it is a leak. Looking at options now on seal, replace coil, replace head, replace unit.
